Need a few schematics
12/23/2012 11:18:39 AMLou
Guys:
I need a few schematics that I have not been able to find:
GE Model K50P cathedral ( an early Christmas Gift)
Beitmans says "its in there" but I cant seem to find it.
Setchell Carlson Model 524 VLF receiver. This is a WWII VLF receiver used in a B17 bomber!!! Just got one and DO want to make it work!!
Thanks for any help
Lou
PS: Hope everyone has a HAPPY HOLIDAY!!!!!!!
EAT LOT OF FOOD, DRINK and BE MERRY!!
Lou
12/23/2012 12:02:09 PMCarl T
:Guys:
:I need a few schematics that I have not been able to find:
:GE Model K50P cathedral ( an early Christmas Gift)
:Beitmans says "its in there" but I cant seem to find it.
:Setchell Carlson Model 524 VLF receiver. This is a WWII VLF receiver used in a B17 bomber!!! Just got one and DO want to make it work!!
:Thanks for any help
:Lou
:PS: Hope everyone has a HAPPY HOLIDAY!!!!!!!
:EAT LOT OF FOOD, DRINK and BE MERRY!!
:Lou
Lou,
Use RCA R28P for the K50P:
http://www.nostalgiaair.org/PagesByModel/691/M0015691.pdf
Carl T
12/23/2012 8:01:09 PMWALTER FROEHLICH
:Guys:
:Lou
:Lou
HI LOU:
THIS IS AN AIRCRAFT LANDING BEACO RECEIVER.IT WAS USED IN MOST WWII AIRCRAFT AND WAS DESIGNED FOR SHORT RANGE,HENCE NOT VERY HIGH SENSITIVITY.IT OPERATES ON 28 VOLTS DC FOR BOTH FILAMENTS AND B+.USING 14V LOCTAL TUBES WITH EACH PAIR IN SERIES.THE ARMY DESIGNATION IS BC-1206CM.YOU CANFIND THE MANUAL AT BAMA LOOKING UNDER MILITARY AND BC-1206.YOU CAN ALSO READ ABOUT IT BY GOOGLE SEARCHING RADIO BOULEVARD/WWII COMMUNICATIONS EQUIPMENT.
I WORKED ON THESE RECEIVERS DURING WWII WHEN I WAS A RADIO MECHAIC IN THE AIR CORP.
WALTER-W2WIQ
12/23/2012 9:02:51 PMLou
::Guys:
::I need a few schematics that I have not been able to find:
::GE Model K50P cathedral ( an early Christmas Gift)
::Beitmans says "its in there" but I cant seem to find it.
::Setchell Carlson Model 524 VLF receiver. This is a WWII VLF receiver used in a B17 bomber!!! Just got one and DO want to make it work!!
::Thanks for any help
::Lou
::PS: Hope everyone has a HAPPY HOLIDAY!!!!!!!
::EAT LOT OF FOOD, DRINK and BE MERRY!!
::Lou
:HI LOU:
:THIS IS AN AIRCRAFT LANDING BEACO RECEIVER.IT WAS USED IN MOST WWII AIRCRAFT AND WAS DESIGNED FOR SHORT RANGE,HENCE NOT VERY HIGH SENSITIVITY.IT OPERATES ON 28 VOLTS DC FOR BOTH FILAMENTS AND B+.USING 14V LOCTAL TUBES WITH EACH PAIR IN SERIES.THE ARMY DESIGNATION IS BC-1206CM.YOU CANFIND THE MANUAL AT BAMA LOOKING UNDER MILITARY AND BC-1206.YOU CAN ALSO READ ABOUT IT BY GOOGLE SEARCHING RADIO BOULEVARD/WWII COMMUNICATIONS EQUIPMENT.
:I WORKED ON THESE RECEIVERS DURING WWII WHEN I WAS A RADIO MECHAIC IN THE AIR CORP.
:WALTER-W2WIQ
Walter:
Thanks for the great info on the aircraft landing receiver. I am going to have GREAT FUN getting it to work again. Thanks Much
Lou
12/24/2012 11:11:12 AMWALTER FROEHLICH
HI LOU:
JUST A SUGGESTION.YOU CAN PUT 2 13.8VDC POWER SUPPLYS IN SERIES TO GET YOUR 27.6VDC.
MERRY CHRISTMAS
WALTER-W2WIQ
:::Guys:
:::I need a few schematics that I have not been able to find:
:::GE Model K50P cathedral ( an early Christmas Gift)
:::Beitmans says "its in there" but I cant seem to find it.
:::Setchell Carlson Model 524 VLF receiver. This is a WWII VLF receiver used in a B17 bomber!!! Just got one and DO want to make it work!!
:::Thanks for any help
:::Lou
:::PS: Hope everyone has a HAPPY HOLIDAY!!!!!!!
:::EAT LOT OF FOOD, DRINK and BE MERRY!!
:::Lou
::HI LOU:
::THIS IS AN AIRCRAFT LANDING BEACO RECEIVER.IT WAS USED IN MOST WWII AIRCRAFT AND WAS DESIGNED FOR SHORT RANGE,HENCE NOT VERY HIGH SENSITIVITY.IT OPERATES ON 28 VOLTS DC FOR BOTH FILAMENTS AND B+.USING 14V LOCTAL TUBES WITH EACH PAIR IN SERIES.THE ARMY DESIGNATION IS BC-1206CM.YOU CANFIND THE MANUAL AT BAMA LOOKING UNDER MILITARY AND BC-1206.YOU CAN ALSO READ ABOUT IT BY GOOGLE SEARCHING RADIO BOULEVARD/WWII COMMUNICATIONS EQUIPMENT.
::I WORKED ON THESE RECEIVERS DURING WWII WHEN I WAS A RADIO MECHAIC IN THE AIR CORP.
::WALTER-W2WIQ
:Walter:
:Thanks for the great info on the aircraft landing receiver. I am going to have GREAT FUN getting it to work again. Thanks Much
:Lou
12/23/2012 8:12:53 PMWALTER FROEHLICH
:Guys:
:Lou
:Lou
HI LOU:
THE SCHEMATIC CAN ALSO BE FOUND IN BEITMANS VOL.1(1926-38) PAGE 169
WALTER-W2WIQ
