crosley 03cp #95
3/31/2012 10:38:50 PMphillip
the power transformer in this radio went bad.i,d like to repair it. new caps etc. belonged to my grandmother.i can,t make it out in the schematics. anybody know which one and where i can get one? any help i,d sure would be thankful. phillip
3/31/2012 10:42:01 PMLou
Try Antique Electronic Supply ( google them ). They will have replacement transformers of different case styles that you can match.
Lou
:the power transformer in this radio went bad.i,d like to repair it. new caps etc. belonged to my grandmother.i can,t make it out in the schematics. anybody know which one and where i can get one? any help i,d sure would be thankful. phillip
3/31/2012 10:43:06 PMNorm Leal
Phillip
Here is a place that sells power transformers. Even if they don't have an exact match one should work:
Be sure filter caps are replaced before powering up the radio with a replacement transformer. Caps may have shorted and caused your transformer to burn out.
4/1/2012 9:43:17 AMphillip
:Phillip thanks so much!
: Here is a place that sells power transformers. Even if they don't have an exact match one should work:
:http://www.oldradioparts.com/2a23efl.txt
: Be sure filter caps are replaced before powering up the radio with a replacement transformer. Caps may have shorted and caused your transformer to burn out.
::the power transformer in this radio went bad.i,d like to repair it. new caps etc. belonged to my grandmother.i can,t make it out in the schematics. anybody know which one and where i can get one? any help i,d sure would be thankful. phillip
