Lou
:The radio is a Japanese AGS AM/FM, circa about 1964. This same radio was also sold as a Rincan, I believe. (I posted earlier about subbing a tube for testing. It was in very rough condition from laying in a damp crawlspace or similar for many years, and I didn't want to waste time on a dud.)
:I procured the 12DT8 tube I needed, repaired a bad connection and cleaned pots and sockets. With new Pioneer speakers salvaged from a pair of car speaker cabs, the radio was performing nicely with excellent reception, and loud enough to rattle the windows!
:I polished up the cabinet and did some rust removal,then tried the chassis back in the cabinet. After about 3 hours total of play, the volume dropped to about half on both AM and FM.
:Here is the tube lineup:
:Two 12DT8 for the FM converter,
:a 12BE6 for AM,
:two 12BA6 IF amps,
:a 12AV6 detector and a 50C5 power tube.
:We are still running the selenium rectumfrier but it is not bad yet. I haven't changed the filter caps, but I brought them up to voltage gently with a variac and there is negligible hum with good B+ voltage readings. The volume pot is quiet and I get a good response from it, but max volume is a fraction of what it was. Has one of the audio amp stages stopped working?
