GE model YRB 83-1, YRB 79-1, YRB 79-2
3/28/2012 4:05:01 PMSteve
Could someone check the schematic and look especially
at the way the pilot bulb is wired in . Also would like to know what # bulb . As soon as I plug in a new bulb = FLASH ! Put new electrolytics in , and replaced most other caps , ( used ) . Tubes all check out fine .
3/28/2012 5:28:45 PMNorm Leal
Steve
Check continuity of your 35Z5GT filament, between pin #2 and #7. This tube has a lamp tap on pin #3. Some tube testers only apply power between the tap and one filament pin. The other is most likely open.
http://www.nostalgiaair.org/PagesByModel/320/M0008320.pdf
:Could someone check the schematic and look especially
:at the way the pilot bulb is wired in . Also would like to know what # bulb . As soon as I plug in a new bulb = FLASH ! Put new electrolytics in , and replaced most other caps , ( used ) . Tubes all check out fine .
9/1/2013 7:13:05 PMBen
Would you be able to help me with a dial cord stringing diagram?
Ben
9/1/2013 7:30:01 PMBrianC
: Would you be able to help me with a dial cord stringing diagram?
:Ben
For what model radio?
9/2/2013 7:44:46 AMNorm Leal
Ben
You can find dial string diagrams here:
http://www.theoldradiofixerupperguy.com/dial%20cord.html
Even if the exact one isn't shown there should be something similar.
:Ben
