Mark:
I think you're right. There seems to be a seperate amplifier and 6H6 for each circuit, AVC and tuning indicator. Maybe the designer of that circuit had a relative in the tube selling business. It would seem to me that you should get negative AVC Voltage from both 6H6s, and it should vary with signal strength. Do you have a problem with AVC or tuning eye?
AVC is a negative Voltage placed on the tube grids to lower the gain of the stage, and when it is not working, you have distortion on strong stations and fading in and out on weaker ones. Sounds to me more like a RF amp problem, maybe an antenna one. I'll get back to you when I've had more coffee, and see about getting the radio working on weak stations, too. I'll study the schematic a little more and write later.
The AVC only reduces the amplification of the tube, so unless you have a high negative Voltage on the AVC line, your problem is somewhere else. That radio has a lot of RF gain, so it might pick up a strong station with a stage completely dead. My gut tells me to check the RF stage for trouble first.
Resistor #4 510K and capacitor #C43--.004 ufd and the bottom leg of #84 dedicated AVC I.F. transformers secondary (These are located around the LOWER 6H6 AVC detector stage. ) 73's de Edd |
:::Lewis: Tuning eye works great. I am having a problem with reception. Only the strongest stations come in. Seems like the AVC may not be working. I have checked the antenna and RF stages. They seem okay, but I'm not sure where the problem is. I have an AM transmitter at home to play music from internet through my radios. That station comes in good - fully closes the tuning eye. AF stage is great - booming sound. Mark
::AVC is a negative Voltage placed on the tube grids to lower the gain of the stage, and when it is not working, you have distortion on strong stations and fading in and out on weaker ones. Sounds to me more like a RF amp problem, maybe an antenna one. I'll get back to you when I've had more coffee, and see about getting the radio working on weak stations, too. I'll study the schematic a little more and write later.
::Lewis
:Hokay, I'm a little more awake now, so let's analyze the schematic. It would appear that this radio has two seperate IF lines, one from the upper 6H6 that only controls the IF tube and the 6G5 tuning eye, and another from the lower 6H6 for the RF amplifier and converter stages. There is a small negative DC Voltage applied to these AVC lines from Resistors 81 and 87. So, to check the AVC, get a high resistance Voltmeter, such as a VTVM or a modern digital meter, as you will never be able to check this grid Voltage with an analog meter. The tuning eye works, so that AVC line is OK. The other line should go negative with received signal strength, about the same as the working one.
:The AVC only reduces the amplification of the tube, so unless you have a high negative Voltage on the AVC line, your problem is somewhere else. That radio has a lot of RF gain, so it might pick up a strong station with a stage completely dead. My gut tells me to check the RF stage for trouble first.
:Lewis
Mark:
I can't think of any reason that they would do it that way either, except as I said, someone must have had a relative in the tube business. Sure seems a complicaated way to do it to me. How 'bout you, Edd?
What'cha think?
P. S. Clock still working fine after what, three years?
Your poor sensitivity on that set is still suggestive of a RF or mixer stage proplem, and not AGC. Standing by . . . .and further wukkin' on da Schematique II
:Edd: I clipped an aerial to the grid of the 6A8 and tried the radio. Performs about the same, a little less gain compared to the antenna connection. MOved it to grid of 6K7 and about the same, maybe a little more gain compared to the 6A8. The only station that seems to come in with any strength is around 1480 (but doesn't move the tuning eye). Middle of the dial is quiet. 590 and 1360 (both local stations) come in with volume cranked nearly all the way up. My SSTran comes in loud at 1430 and closes the tuning eye - the two halves actually overlap. Mark from Kalamazoo
