http://www.philcorepairbench.com/tips/svctip43.htm
And This too.
http://www.philcorepairbench.com/tips/svctip44.htm
:This is from the Philco Repair Bench. This may get you a bit more amplification from your 80.
:http://www.philcorepairbench.com/tips/svctip43.htm
:And This too.
:http://www.philcorepairbench.com/tips/svctip44.htm
:And This too.
:This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
:Warren,
: I'll replace all of the ones you mention.
:Thanks,
:Dave
::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
:Warren,
:Thanks,
:Dave
Do you have voltages similar to ones marked on the Rider schematic?
http://www.nostalgiaair.org/PagesByModel/843/M0013843.pdf
This is only a 4 tube radio and depends on regeneration in the IF stage. Have you peaked adjustments?
:Warren,
: I replaced 19, 20, 22, and 26 and the amplifier still has no oomph. Now what?
: The hum when I touch the top pin should be way way way way way louder.
: The amplifier has no oomph. The tuner is working perfectly.
:Thanks,
:Dave
::Warren,
:: I'll replace all of the ones you mention.
::Thanks,
::Dave
:::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
What would you like to know?
:Dave
: Do you have voltages similar to ones marked on the Rider schematic?
:http://www.nostalgiaair.org/PagesByModel/843/M0013843.pdf
: This is only a 4 tube radio and depends on regeneration in the IF stage. Have you peaked adjustments?
::Warren,
:: I replaced 19, 20, 22, and 26 and the amplifier still has no oomph. Now what?
:: The hum when I touch the top pin should be way way way way way louder.
:: The amplifier has no oomph. The tuner is working perfectly.
::Thanks,
::Dave
:::Warren,
::: I'll replace all of the ones you mention.
:::Thanks,
:::Dave
::::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
::The plate voltage is way to high on the 36 tube. This would seem to indicate the tube is not working. The cathode being grounded would depend on resistor 36 a wire wound 325 ohm from the center tap of the power transformer. The same goes for the cathode of the output tube.
:Warren,
: I have no Idea how that just happened. The message was from me, not you. Anyway, I checked voltages and connections and all connections are good. I'll check it again. The connection from the 2nd 36 to the chassis is being made by a rivet. My meter says .003 ohms. It's firmly connected to the chassis. I have tried other tubes from radios that blast and they refuse to work here.
: Now on to the 42. There is a wire connecting it's cathode directly to the chassis. My meter says that it's .001 ohms. This is lower than the chassis rivet connection. I have had hum problems from bad rivet connections. I'll use my clip lead to get it better connected to the chassis. From the grid of the 42 through to the coil resistor and B- is 475 K ohms. I don't have a 490. Then onto the chassis it's 311 ohms. The tubes have to be on. What would make it not conduct?
:Thanks,
:Dave
:::The plate voltage is way to high on the 36 tube. This would seem to indicate the tube is not working. The cathode being grounded would depend on resistor 36 a wire wound 325 ohm from the center tap of the power transformer. The same goes for the cathode of the output tube.
You learned what most of the old timers learned a long time ago. Just because it is new doesn't mean it is good. I always check new caps before installing.
Clifton
:Warren,
: The problem turned out to be a shorted brand new bypass capacitor. I replaced it and the radio blasts. There is now 45.8 volts on the second detector side of the 10K ohm resistor.
: This "new" capacitor wasted my time. I'll complain to the place that sold it to me and check all the others of that type for more shorts.
: With all new capacitors and resistors and "gimmick" capacitor, it sounds fantastic!
:Thanks,
:Dave
::Warren,
:: I have no Idea how that just happened. The message was from me, not you. Anyway, I checked voltages and connections and all connections are good. I'll check it again. The connection from the 2nd 36 to the chassis is being made by a rivet. My meter says .003 ohms. It's firmly connected to the chassis. I have tried other tubes from radios that blast and they refuse to work here.
:: Now on to the 42. There is a wire connecting it's cathode directly to the chassis. My meter says that it's .001 ohms. This is lower than the chassis rivet connection. I have had hum problems from bad rivet connections. I'll use my clip lead to get it better connected to the chassis. From the grid of the 42 through to the coil resistor and B- is 475 K ohms. I don't have a 490. Then onto the chassis it's 311 ohms. The tubes have to be on. What would make it not conduct?
::Thanks,
::Dave
::::The plate voltage is way to high on the 36 tube. This would seem to indicate the tube is not working. The cathode being grounded would depend on resistor 36 a wire wound 325 ohm from the center tap of the power transformer. The same goes for the cathode of the output tube.
:Warren,
:Thanks,
:Dave
::Warren,
::Thanks,
::Dave
Warren mentioned plate voltage is way too high. This could mean screen is too low so your 36 isn't drawing enough current. Be sure plate & screen resistors haven't drifted in value. Check screen bypass cap for leakage.
Be sure you have a 36 tube and not 39/44.
:Warren,
: I made the "gimmick" capacitor and checked all the resistors. Everything checks good and the amplifier still has no oomph. This is extremely frustrating.
:Thanks,
:Dave
::Warren,
::Thanks,
::Dave
:::Warren,
:::Thanks,
:::Dave
:Dave
: Warren mentioned plate voltage is way too high. This could mean screen is too low so your 36 isn't drawing enough current. Be sure plate & screen resistors haven't drifted in value. Check screen bypass cap for leakage.
: Be sure you have a 36 tube and not 39/44.
::Warren,
:: I made the "gimmick" capacitor and checked all the resistors. Everything checks good and the amplifier still has no oomph. This is extremely frustrating.
::Thanks,
::Dave
:::Warren,
::: I replaced 19, 20, 22, and 26 and the amplifier still has no oomph. Now what?
::: The hum when I touch the top pin should be way way way way way louder.
::: The amplifier has no oomph. The tuner is working perfectly.
:::Thanks,
:::Dave
::::Warren,
:::: I'll replace all of the ones you mention.
::::Thanks,
::::Dave
:::::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
What are your plate & screen voltage? The plate is supplied through a couple resistors. So is the screen. When a tube draws current plate voltage will drop across the resistor.
Warren mentioned your plate voltage was way too high on 2nd detector tube.
A tube will not draw current if the screen voltage isn't positive. Also cathode and grid #1 have to be close in voltage. Both are connected or referenced to ground
Leakage can come from a screen bypass cap reducing voltage. Resistor off value can also give wrong voltages. Double check plate (240K) & screen (1 Meg) resistors. Try reversing 36 tubes.
:Norm,
: A components are brand new. Where could this "leakage" come from?
:Thanks,
:Dave
::Dave
:: Warren mentioned plate voltage is way too high. This could mean screen is too low so your 36 isn't drawing enough current. Be sure plate & screen resistors haven't drifted in value. Check screen bypass cap for leakage.
:: Be sure you have a 36 tube and not 39/44.
:::Warren,
::: I made the "gimmick" capacitor and checked all the resistors. Everything checks good and the amplifier still has no oomph. This is extremely frustrating.
:::Thanks,
:::Dave
::::Warren,
:::: I replaced 19, 20, 22, and 26 and the amplifier still has no oomph. Now what?
:::: The hum when I touch the top pin should be way way way way way louder.
:::: The amplifier has no oomph. The tuner is working perfectly.
::::Thanks,
::::Dave
:::::Warren,
::::: I'll replace all of the ones you mention.
:::::Thanks,
:::::Dave
::::::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
Thanks Very Very Much,
:Dave
: What are your plate & screen voltage? The plate is supplied through a couple resistors. So is the screen. When a tube draws current plate voltage will drop across the resistor.
: Warren mentioned your plate voltage was way too high on 2nd detector tube.
: A tube will not draw current if the screen voltage isn't positive. Also cathode and grid #1 have to be close in voltage. Both are connected or referenced to ground
: Leakage can come from a screen bypass cap reducing voltage. Resistor off value can also give wrong voltages. Double check plate (240K) & screen (1 Meg) resistors. Try reversing 36 tubes.
::Norm,
:: A components are brand new. Where could this "leakage" come from?
::Thanks,
::Dave
:::Dave
::: Warren mentioned plate voltage is way too high. This could mean screen is too low so your 36 isn't drawing enough current. Be sure plate & screen resistors haven't drifted in value. Check screen bypass cap for leakage.
::: Be sure you have a 36 tube and not 39/44.
::::Warren,
:::: I made the "gimmick" capacitor and checked all the resistors. Everything checks good and the amplifier still has no oomph. This is extremely frustrating.
::::Thanks,
::::Dave
:::::Warren,
::::: I replaced 19, 20, 22, and 26 and the amplifier still has no oomph. Now what?
::::: The hum when I touch the top pin should be way way way way way louder.
::::: The amplifier has no oomph. The tuner is working perfectly.
:::::Thanks,
:::::Dave
::::::Warren,
:::::: I'll replace all of the ones you mention.
::::::Thanks,
::::::Dave
:::::::This radio depends on the signal strength for how loud it would play. Could use an alignment for maximum signal to the audio output stage. Check resistors 11-19-20-22-26
Good to hear you fixed the radio. Years ago I had problems with similar caps when a lead or other sharp object would poke the side. When it went through it would short the cap. Might look for a small hole on the side?
:There have been a few reports of those yellow capacitors being defective. It would be a good idea to check your entire inventory to avoid this in the future.
:Dave
: Good to hear you fixed the radio. Years ago I had problems with similar caps when a lead or other sharp object would poke the side. When it went through it would short the cap. Might look for a small hole on the side?
::There have been a few reports of those yellow capacitors being defective. It would be a good idea to check your entire inventory to avoid this in the future.
