From my Marconi Tube Characteristics Manual, the pinouts for a 12AX7 are the same as the 12DT8, except for the filament center tap, which I won't need. However, there are differences as follows:
Max plate Watts Capacitance in pfd
Input Output grid-plate
12DT8 2.7 2.7 1.6 1.6
12AX7 1.0 1.8 1.9 1.7
12AT7 2.5 2.2 1.2 1.5
As you can see, a 12AT7 would be a closer match, but I am not sure if I have one handy.
1) Is the plate watts rating a serious factor? Would it be foolish to try a 12AX7?
It looks like one side of the tube will be AM and the other side FM.
2) Should the substitute go in the first socket, at the antenna input, or the second, after the 1st IF transformer?
Forget the 12AX7. And I don't have a 12AT7.
What I found in my boxes is 12AU7's and a couple of 5963's, I think they're a milspec twin triode. Here are the specs:
Max plate Watts
12DT8 2.7
12AU7 2.75
5963 2.5
Capacitance in pfd
Input, Output, grid-plate 12DT8 2.7 1.6 1.6
Input, Output, grid-plate 12AU7 1.8 2.0 1.5
Input, Output, grid-plate 5963 1.9 0.5 1.5
I'm going to try a 12AU7, unless somebody tells me otherwise.
Once it is working and looks worth it, then get your 12DT8. Until then make sure pin 9 is disconnected.
Best Regards,
Bill Grimm
http://pacifictv.ca/main.htm#NOS
:I have a tube question. The radio is a mid-60's AGS, Japanese AM/FM, similar to a Rincan, that has water damage, I wonder if it floated, but is complete. It is a transformerless design that uses 2 12DT8 9-pin tubes in the RF amp stages. One tube is cracked, so I need to substitute, at least for now until I know it's worth continuing. :>)
:From my Marconi Tube Characteristics Manual, the pinouts for a 12AX7 are the same as the 12DT8, except for the filament center tap, which I won't need. However, there are differences as follows:
: Max plate Watts Capacitance in pfd
: Input Output grid-plate
:12DT8 2.7 2.7 1.6 1.6
:12AX7 1.0 1.8 1.9 1.7
:12AT7 2.5 2.2 1.2 1.5
:As you can see, a 12AT7 would be a closer match, but I am not sure if I have one handy.
:1) Is the plate watts rating a serious factor? Would it be foolish to try a 12AX7?
:It looks like one side of the tube will be AM and the other side FM.
:2) Should the substitute go in the first socket, at the antenna input, or the second, after the 1st IF transformer?
