milliamp meter connection
11/28/2001 9:26:50 PMCharles McBurney
I have a panel mount milliamp meter that I would like to use to monitor the amperage draw of any radio that I am powering up with a variac. How do I do this without destroying the meter?
11/28/2001 11:58:38 PMJohn McPherson
You will need to use your math skills and "Ohm's Law" to devise a resistor network that will allow your meter to read the current across a low resistance shunt in series with another low value resistor, and you may need to use a selector switch for multiple ranges.
: I have a panel mount milliamp meter that I would like to use to monitor the amperage draw of any radio that I am powering up with a variac. How do I do this without destroying the meter?
11/30/2001 9:00:25 AMRussell Kincaid
: Hi,
: You will need to use your math skills and "Ohm's Law" to devise a resistor network that will allow your meter to read the current across a low resistance shunt in series with another low value resistor, and you may need to use a selector switch for multiple ranges.
: : I have a panel mount milliamp meter that I would like to use to monitor the amperage draw of any radio that I am powering up with a variac. How do I do this without destroying the meter?
If you are measuring the AC current input and have a DC milliammeter, a diode bridge will work. But you still need the shunt resistors as noted above.
4/4/2002 12:06:48 AMCarrie
Sorry, to break up your question, but I have been wondering, what *is* a milliamp? Is it a smaller than a volt? What is it?
