Should go by circuits at Atwater Kent Info site:
http://www.atwaterkent.info/TechData/Images/SM2808_060.gif
The supply does use two filter chokes. It was less expensive that using large value filter caps. I replace the filters with 10 mf @ 450 volt caps.
The third choke is a plate load for 71A tube. If damaged you can use a small output transformer without connecting the secondary.
:Hi All Again, well I got the tar out of the Condenser side of the 37 Power Supply and was shocked by all of the stuff they stuffed into it. A daul choke rated at 1600 ohms, one 500 ohm choke and around nine capacitors. Problem is the schematic shows the chokes and I can probably get replacement for them but why is there such a large difference in the capacitors? I'd like to rebuild it but I'm soooo confused is anybody out there familiar with these power suppies. Thanks a Million, George T
:George
: Should go by circuits at Atwater Kent Info site:
:http://www.atwaterkent.info/TechData/Images/SM2808_060.gif
: The supply does use two filter chokes. It was less expensive that using large value filter caps. I replace the filters with 10 mf @ 450 volt caps.
: The third choke is a plate load for 71A tube. If damaged you can use a small output transformer without connecting the secondary.
::Hi All Again, well I got the tar out of the Condenser side of the 37 Power Supply and was shocked by all of the stuff they stuffed into it. A daul choke rated at 1600 ohms, one 500 ohm choke and around nine capacitors. Problem is the schematic shows the chokes and I can probably get replacement for them but why is there such a large difference in the capacitors? I'd like to rebuild it but I'm soooo confused is anybody out there familiar with these power suppies. Thanks a Million, George T
http://www.atwaterkent.info/Articles/AKPower.pdf
