Schematics for Silverton
11/27/2001 11:39:55 PMLeon Vose
I have a Silverton C187-41650 6 Tube AM Radio that I
am trying to find schematics and some info on. I need a
type layout and any info on the antenna area. It fades
in and out and if I touch the antenna solder area it can
cause the problem immediately.
Does anyone have any info on this?
Thanks in advance
11/28/2001 7:33:35 PMNorm Leal
Hi Leon
Didn't find C187 but you can check at the following address to see if there are any numbers that match. Silvertone is Sears. If it has Silverton may be a copy of Sears?
http://www.nostalgiaair.org/Riders/SRC.htm
: I have a Silverton C187-41650 6 Tube AM Radio that I
: am trying to find schematics and some info on. I need a
: type layout and any info on the antenna area. It fades
: in and out and if I touch the antenna solder area it can
: cause the problem immediately.
: Does anyone have any info on this?
: Thanks in advance
11/29/2001 12:53:34 AMLeon Vose
I have checked there and did not find it. The model I think
is 4165. I did see a picture of one on antiqueradio.org that
was listed as a Silvertone 4165.
: Hi Leon
: Didn't find C187 but you can check at the following address to see if there are any numbers that match. Silvertone is Sears. If it has Silverton may be a copy of Sears?
: http://www.nostalgiaair.org/Riders/SRC.htm
: Norm
: : I have a Silverton C187-41650 6 Tube AM Radio that I
: : am trying to find schematics and some info on. I need a
: : type layout and any info on the antenna area. It fades
: : in and out and if I touch the antenna solder area it can
: : cause the problem immediately.
: : Does anyone have any info on this?
: : Thanks in advance
11/29/2001 1:40:26 AMNorm Leal
Hi Leon
Found a Sears 4165 listed in Sam's Photofact #699. It's too new for Rider. Check with your local library. They usually can get Sam's Photofacts. If not, you can call Sam's at 800-428-7267 or check their web site.
http://www.samswebsite.com/photofacts.html
: I have checked there and did not find it. The model I think
: is 4165. I did see a picture of one on antiqueradio.org that
: was listed as a Silvertone 4165.
: Thanks
: : Hi Leon
: : Didn't find C187 but you can check at the following address to see if there are any numbers that match. Silvertone is Sears. If it has Silverton may be a copy of Sears?
: : http://www.nostalgiaair.org/Riders/SRC.htm
: : Norm
: : : I have a Silverton C187-41650 6 Tube AM Radio that I
: : : am trying to find schematics and some info on. I need a
: : : type layout and any info on the antenna area. It fades
: : : in and out and if I touch the antenna solder area it can
: : : cause the problem immediately.
: : : Does anyone have any info on this?
: : : Thanks in advance
