emerson t.v. 7" screen
3/5/2012 9:32:45 PMsmith
i am in need of 5 caps, 3 of .001 @ 6000 volts and 2 of .005 @ 6000 volts.just radios had them for 100 dollars.anybody know anyone cheaper.
3/5/2012 10:10:26 PMWarren
Ceramic disk capacitors can be found at a regular electronics parts supply. Such as Mouser Electronics or Parts Express. The capacitors are in the PF value. You need 1000 pf @ 6000 and 5000 pf @ 6000 These cost less than a couple of bucks each.
3/7/2012 5:03:44 PMsmith
:Ceramic disk capacitors can be found at a regular electronics parts supply. Such as Mouser Electronics or Parts Express. The capacitors are in the PF value. You need 1000 pf @ 6000 and 5000 pf @ 6000 These cost less than a couple of bucks each.
:i ordered the caps.
