Richard
Did you retest that tube after it occurred? Maybe it failed, either becaue of another issue, or just picked a bad time to die...
Think of it this way...you must be close if it worked for ~10s... ;-)
:::If you have not made basic voltage checks. There is a voltage chart. Most problems are found this way. Open coils are a real possibly given its age, ca. 1932. T2 that drives the power amp or the RF plate coil L4 among others for such a vintage radio.
:::Richard
::Sounds like it may be something intermittent or shorting. I would also check around the 'blue glow' tube. It might be indication of a problem / overload there.
::Did you retest that tube after it occurred? Maybe it failed, either becaue of another issue, or just picked a bad time to die...
::Think of it this way...you must be close if it worked for ~10s... ;-)
:Could also be related to the missing cap causing some other component to fail...
:I see what you mean by the resistance reading from terminal 2 of the phonograph input. have you removed the 2nd detector tube to make this reading? Or take a reading from the grid to chassis? (trace in reverse)
All the wires to both IF transformers were touching the chassis. R8 was disconnected from the cathode of the detector tube. The signal overloads the tuner but it has no AVC in these sets. So the 150 ohm resistor will probably help. I just shortened the antenna. That helped.
I am still borrowing this speaker from a r-7, which is un-restored. So I either need one for it, because I'll probably restore it too.
Thanks to everyone,
