If the cathode bias resistor (now burned up)in series with a .01 cap is a valid hookup, what would a typical value be? I might try that.
Thanks, Warren. I will check the tube. I don't have a tube tester anymore, but a short should be easy to detect?
That resistor was replaced once and burned again, with the original power tube still in place.
Pin 2 of the 12AT6 is indeed wired straight to the B-, so it is biased correctly after all. They tied pins 2 and 5 together and there is a small black wire from pin 5 to a terminal on the volume pot, which is at B- potential.
(After I printed off a schematic and changed the pin numbers, it began to make more sense :>)
Update - the tube does not indicate a dead short between the heater and cathode when cold. When hot, maybe. When I first checked it out, I saw the black resistor, but the heaters warmed up ok, before the tendrils of smoke told me to shut her down.
One other thing I did not mention - the 12AT6 has been switched out. It is actually a 12AV6. Would the slightly more powerful preamp tube affect the power tube bias resistor in a bad way?
And finally, I have a few 180 ohm resistors. Should I use that or go look for a 150 ohm?
With the old tubes in, burnt resistor, electrolytics and paper caps replaced, the radio played well for 3 mins, then volume cut out to very faint and garbled. When I cut power, volume peaked for a second. I'll try some tube substitutions manyana. The new resistor stayed cool.
Thanks, Warren, this helps a lot.
My patient is determined to die in the OR. The symptoms are worse every time I power it up. Earlier today, touching the slug on IF1 with a screwdriver brought the volume back for a moment or two. When that wore off, doing the same on IF2 had a similar but more short lived effect. Now, this no longer does the trick.
So on the bright side, this can't be a gradual corrosion on the silver/mica in the IF cans. That's my theory and I'm sticking to it (till proven wrong:>).
I found R7 was high at about 420K, just like you predicted, so I subbed it temporarily with a variable R set to 330K. C9 had been replaced before by a .01 mfd, so I replaced it with a .02 per the schemo.
Now, the radio is very quiet and no longer responding to stray capacitance or whatever was working before. 12AV6 plate voltage is about 63 vdc, 50L6 plate is about 83 vdc.
C15 and 16 and the resistor between them appears to be a small ceramic unit with 3 leads. I've been trying to ignore it, but since you are pointing in that direction, I will next try bypassing that with some discreet components.
R13 measures 39K ohms and there is infinite R across the caps, C15 and C16.
What was odd, was that the volume stayed up after removing the screwdriver, then died away after 2 minutes. It's a plastic handled screwdriver with about 2 inches of steel blade. This PM, I wasn't able to recreate this phenomenon. The radio still plays a strong local station, but is very weak.
These are the mini IF cans with only one slug and they are suspects, all right. I'll check them both for shorts.
Update - the culprit was a cold solder joint, where 4 components and a lead from IF 1 all come together on a terminal strip. Although I'd resoldered that point, the lead from the IF secondary was making intermittent contact.
