This is only checking the coil continuity.
The 2nd IF secondary has a 47 kilo-ohm resister in series with its lug.
This meter check isn't testing the capacitors or tunability/stability of the IF xformers. That would be determined by actually aligning and playing the radio.
: This is only checking the coil continuity.
: The 2nd IF secondary has a 47 kilo-ohm resister in series with its lug.
: This meter check isn't testing the capacitors or tunability/stability of the IF xformers. That would be determined by actually aligning and playing the radio.
