My 1949 Marconi FM252 is recapped and repaired and received FM OK while out on the bench with a simple dipole antenna attached, but now that it is up on the special shelf I built to take a 40 lb brute of a table radio, FM is gone, even with an external antenna. Before I rig something outside for it, I would like to try a power cord antenna. An alignment would also be helpful, I'm sure, but first a good antenna.
Can anyone steer me towards a design? Is the length of the power cord critical? I suspect this system utilizes the whole house wiring as a big loop antenna?, but would like some more info.
Thanks, Warren. I will have to experiment, as I have two terminals on the Marconi, as well as a grnd screw.
