What model is the radio?
Generally you have to isolate the particular stage that the noise is generated in and then isolate down to the component or connection level.
The larger electrolytic caps might introduce a hum if defective, not a crackle.
: What model is the radio?
: Generally you have to isolate the particular stage that the noise is generated in and then isolate down to the component or connection level.
: The larger electrolytic caps might introduce a hum if defective, not a crackle.
Clifton
:Try cleaning the AM&FM selector switch with a little spray contact cleaner. Rotate the switch back a forth a bunch of times. A little shot in the volume control. This radio does have electrolytic capacitors both big and small everywhere. Sometimes you get lucky and can see a crud leaking from the bottoms down the leads. That one needs to be replaced. Have a good look with a magnifier.
