:Why do some radio manufactors put in a electrolytic cap across the Cathode resistor and some do not. I know it has to due with bypassing certain low audio frequencies. The size cap is around 10mfd @ 25-50 VDC. On another thought, what would change or for the better or worse if you installed a bypass cap across the 12SK7 IF amp Cathode resistor.
Hi Frank,
I have not often seen cathode capacitors across the power output tubes in AC/DC sets. This is rarely done, or never done, because suppression of 60Hz hum is a main consideration in these sets and a bypass capacitor helps pass 60Hz. Leaving it off helps suppress 60Hz hum.
As for a bypass capacitor on a 12SK7, I have seen 0.005uF or there a bouts in that place. One wants to make sure the IF is passed. I usually see that in the circuit.
Best Regards,
Bill
