Replacing Old 2 Prong AC Plug With New
2/2/2012 9:59:49 AMBrianC
When using a newer style 'keyed' style AC plug for a radio replacement...Does the wide blade get the chassis 'ground' side or the circuit 'hot' side? Also, would a 3 prong cord/plug be adaptable to these old ac/dc sets with the 'hot' chassis?
2/2/2012 10:24:31 AMWarren
The wide pin is the common side of a polarized line cord. This would be the switched side going to chassis ground on a hot chassis. Do not use a three pin cord with earth ground.
2/2/2012 4:33:09 PMBrianC
Got it...Thanks Warren!
2/3/2012 12:31:50 PMStephen
I would recommend changing their cord wiring to this:
http://www.angelfire.com/electronic/funwithtubes/AA5-6.html
It will make the radio chassis a tad safer by rewiring the switch so the "hot" side of the line is switched and connecting the polarized plug this way.
:When using a newer style 'keyed' style AC plug for a radio replacement...Does the wide blade get the chassis 'ground' side or the circuit 'hot' side? Also, would a 3 prong cord/plug be adaptable to these old ac/dc sets with the 'hot' chassis?
2/4/2012 10:16:49 PMJohn Kogel
That is an excellent and well written guide for adding a new cord, but ... you may want to tie the knot in the cord BEFORE making the soldered connections. :>)
:I would recommend changing their cord wiring to this:
:http://www.angelfire.com/electronic/funwithtubes/AA5-6.html
:It will make the radio chassis a tad safer by rewiring the switch so the "hot" side of the line is switched and connecting the polarized plug this way.
::When using a newer style 'keyed' style AC plug for a radio replacement...Does the wide blade get the chassis 'ground' side or the circuit 'hot' side? Also, would a 3 prong cord/plug be adaptable to these old ac/dc sets with the 'hot' chassis?
