Best Regards,
Bill Grimm
GRUNDIG UNITIZED 7035 MUSIKSCHRANK SCHEMATIC: ![]() |
:Hi ya'll,
: I am looking for a schematic for this radio. It seems quite scarce. I need the 'USA' version not the 'WE' version, as they are different.
: Any ideas on where one can be found?
:Best Regards,
:Bill Grimm
Now I see that on the cathode of the output tube we have 821721 volts. The cahtode resistor is 170 ohms. Obviously the one in there is way too small. Do you know where I can find a 170 ohm resistor 115 trillion watt?
Someone else found the USA schematic. Oddly it looks quite a bit different. I would not have expected that kind of difference. I am looking in the power output section around the output transformer. Your schematic shows two taps and the other schematic shows one tap and it seems that is what I have in the radio.
Anyway, I may be writing back as it has a really odd problem.
Thanks again!
Bill Grimm
