B&K MODEL 700 TUBE TESTER ..NEED MANUAL/TUBE CHARTS
1/24/2012 12:29:44 AMgeorge
Hello... I recently aquired and B&K model 700 tube tester and do not have the manual/tube chart sheets.. Would anyone happen to have this or could make me a copy??
1/24/2012 1:05:46 AMNorm Leal
Hi George
You can find the information here:
http://bama.edebris.com/manuals/b&k/
:Hello... I recently aquired and B&K model 700 tube tester and do not have the manual/tube chart sheets.. Would anyone happen to have this or could make me a copy??
1/24/2012 3:57:23 PMGeorge to Norm
Norm its says that ..that site has been down since 2009
:Hi George
: You can find the information here:
:http://bama.edebris.com/manuals/b&k/
::Hello... I recently aquired and B&K model 700 tube tester and do not have the manual/tube chart sheets.. Would anyone happen to have this or could make me a copy??
1/24/2012 4:30:07 PMNorm Leal
George
It says the main BAMA site has been down. This one is called Mirror site. Look below the notes and you will find B&K 700 information.
:Norm its says that ..that site has been down since 2009
::Hi George
:: You can find the information here:
::http://bama.edebris.com/manuals/b&k/
:::Hello... I recently aquired and B&K model 700 tube tester and do not have the manual/tube chart sheets.. Would anyone happen to have this or could make me a copy??
1/24/2012 11:25:00 PMGeorge THANKS!!
Ahhh ..dahhh stupid me I see it THANKS .. WOW THATS GREAT I CAN GET BOTH FOR FREE...PERFECT!!!
:George
: It says the main BAMA site has been down. This one is called Mirror site. Look below the notes and you will find B&K 700 information.
::Norm its says that ..that site has been down since 2009
:::Hi George
::: You can find the information here:
:::http://bama.edebris.com/manuals/b&k/
::::Hello... I recently aquired and B&K model 700 tube tester and do not have the manual/tube chart sheets.. Would anyone happen to have this or could make me a copy??
1/24/2012 7:39:42 PMRichard
George,
To make it easier here are the links directly to where you can download the manual and tube data:
http://bama.edebris.com/manuals/b&k/700/
http://bama.edebris.com/manuals/b&k/700tubes/
Hope this helps,
Richard
1/24/2012 11:27:16 PMGeorge ahhh THANKS
:George
:George,
:To make it easier here are the links directly to where you can download the manual and tube data:
:http://bama.edebris.com/manuals/b&k/700/
:http://bama.edebris.com/manuals/b&k/700tubes/
:Hope this helps,
:Richard
1/27/2012 12:40:56 AMGeorge... no manual for this
on the bama site there is no instruction manual..anyone have this as a pdf file?
1/27/2012 1:30:05 AMWarren
on the bama site there is two full manuals that originally came with the tube tester. One is in the .pdf format, the other same one is .djvu .. There is also the tube chart for this model.
1/27/2012 2:25:52 AMGeorge...manual
I down-loaded the tube chart but when I down-loaded the manual (twice) all i got was just the front booklet cover... Anyway I found manual on other site and can send all the pages to someone if tehy also need this
1/27/2012 1:25:23 PMCarl T
:I down-loaded the tube chart but when I down-loaded the manual (twice) all i got was just the front booklet cover... Anyway I found manual on other site and can send all the pages to someone if tehy also need this
The manual is there. I don't know why you only got the cover page.
http://bama.edebris.com/download/b&k/700/b&k_700.pdf
Carl T
