Hickok 600A
1/12/2012 9:09:34 AMMark
The only way I can set the line adjust to the line test line on the meter is to turn the adjust knob to approx 105v. I tried another 83 tube but when I tried to adjust the line voltage again I had to turn it down to approx 105 v and it burned out the 83 tube.
Can someone please tell me were I should start troubleshooting from or is this something I should send to a qualified repair person. I do have the schematics foe the unit.
Thank you.
1/13/2012 8:33:18 PMEdd
Sir Mark . . . . .
I'm providing you with my additional UNITIZED schematic of that unit.
" Can someone please tell me were I should start troubleshooting from or is this something I should send to a qualified repair person."
Since you DO have the tech info . .don't berate your capabilities . . .you 'da man !
Upon perusing the units design we see no basic DC power supply and its electrolytic filter bank, since the unit is using the positive nodes of the power supply.
But on going with your good analytical info provided, do note that the accuracy of the meter circuitry is dependent upon the conversion of its incoming AC signal level ito a stable DC level to operate the meter proper.
I would say that after umpteen . .(to the power of 2) . . . years, that the C3 marked up electrolytic has diminished down into the few farads catagory.
With you then getting an erroneous meter reading you were adjusting the R16 AC line series dropping pot to the erroneous reading that you were actually getting.
Confirm if this is the situation, and while you gots the hood up, see if [Aqua-blue] marked up fuse lamp might have also been damaged.
Another confirming procedure would be to use AC meter to monitor the 5Y3 and 83's filaments supplys to see how close they are to 5 VAC WHEN the line set is at its mark . . .(not your MARK, its mark). hi hi
Thassitt . . . . .
Pee Ess . . .Be real caredfull with that thar' tube tester of yours . . . its rocket powered!
Notice at the VERY TOP-LEFT corner of the schematic page , theres a BLAST OFF !
Now . . . for some fascinating medical news:
Doctors are now starting to use maggots to heal wounds. Now, this just doesn't make any sense to me.
Now I ask you .... when is the last time you saw an animal on the side of the road, all covered with maggots,that looked like it was getting any better ?
HICKOK UNITIZED 600A TUBE TESTER SCHEMATIC:
:The only way I can set the line adjust to the line test line on the meter is to turn the adjust knob to approx 105v. I tried another 83 tube but when I tried to adjust the line voltage again I had to turn it down to approx 105 v and it burned out the 83 tube.
:Can someone please tell me were I should start troubleshooting from or is this something I should send to a qualified repair person. I do have the schematics foe the unit.
:Thank you.
