First issue so far is a (diagram # 16) resistor valued at 5000 ohm 1/4 watt in parallel with a .05 condenser (diagram # 15). The resistor measures 6400 ohms and will be destroyed anyway because it's wrapped so tight within a set of coils (6A8 section). I have (from Radioshack) a 4700 ohm 1/2 watt and a 6800 ohm 1 watt from just radios.
If the 6800 is out of tolerance by more than 30%, would the 4700 undervalued be within tolerance and safe? The working space within the set of coils is very small and don't want to order a minimum for 1 resistor.
Thank you,
Vinny A.
Use 4700 ohm resistor. It's within tolerance (6%)and is a replacement for 5000 ohms.
:Greetings,
:I have just started a restoration on a American Bosch 595P Centr-O matic. http://www.nostalgiaair.org/resources/331/M0022331.htm
:First issue so far is a (diagram # 16) resistor valued at 5000 ohm 1/4 watt in parallel with a .05 condenser (diagram # 15). The resistor measures 6400 ohms and will be destroyed anyway because it's wrapped so tight within a set of coils (6A8 section). I have (from Radioshack) a 4700 ohm 1/2 watt and a 6800 ohm 1 watt from just radios.
:If the 6800 is out of tolerance by more than 30%, would the 4700 undervalued be within tolerance and safe? The working space within the set of coils is very small and don't want to order a minimum for 1 resistor.
:Thank you,
:Vinny A.
Warren, thank you for responding. I a little confused as to the replacement. There both out of tolerance, should I go by the schematic value or should I go by what's in the radio? The value for each on the schematic is 1/2 meg but the color coded resistors in the radio by chart are 250k.
Vinny A.
Warren, thanks again. I have only a radio shack 270k 1/2 watt that I will be using. Not exact but within tolerance (as to what's inside the radio). This is the oldest and by far the most complicated radio that I have worked on and I am only just starting it, even the solder on the lugs is like a rock to get through.
I noticed that some of the values of resistors you can not even buy. So let me ask a couple of questions: Is it better to be within +/- tolerance or to put some resistors in parallel to achieve the desired "0" tolerance value? And, why are there different values in the radio (which looks original) vs the schematic? would it maybe have been a production change on the fly or a dollars and cents thing post depression?
Thank you again,
Vinny
