923 Tube
12/16/2011 9:22:52 PMplanigan
Can anyone steer me to a site where I can get the info on this tube. I think it is a sensor of some type as the "plate" is semicircular(not closed and the "cathjode" is centered in the semicircle. PL
12/16/2011 9:44:27 PMNorm Leal
Hi
You have a photocell. You can test it with a meter that uses a 22 1/2 or 30 volt battery for the high ohms scale. Connect the 923 across leads while on highest resistance range. Shine light on the tube. Meter deflection will increase.
http://frank.pocnet.net/sheets/049/9/923.pdf
:Can anyone steer me to a site where I can get the info on this tube. I think it is a sensor of some type as the "plate" is semicircular(not closed and the "cathjode" is centered in the semicircle. PL
12/17/2011 2:12:55 PMJohn
:Hi
: You have a photocell. You can test it with a meter that uses a 22 1/2 or 30 volt battery for the high ohms scale. Connect the 923 across leads while on highest resistance range. Shine light on the tube. Meter deflection will increase.
:http://frank.pocnet.net/sheets/049/9/923.pdf
::Can anyone steer me to a site where I can get the info on this tube. I think it is a sensor of some type as the "plate" is semicircular(not closed and the "cathjode" is centered in the semicircle. PL
Specs here: http://tubedata.milbert.com/sheets/049/9/923.pdf
12/28/2011 1:08:56 AMplanigan
::Hi
:: You have a photocell. You can test it with a meter that uses a 22 1/2 or 30 volt battery for the high ohms scale. Connect the 923 across leads while on highest resistance range. Shine light on the tube. Meter deflection will increase.
::http://frank.pocnet.net/sheets/049/9/923.pdf
:::Can anyone steer me to a site where I can get the info on this tube. I think it is a sensor of some type as the "plate" is semicircular(not closed and the "cathjode" is centered in the semicircle. PL
:Specs here: http://tubedata.milbert.com/sheets/049/9/923.pdf
Thanks for the replys.
12/17/2011 2:13:10 PMJohn
:Hi
