41-611 -capacitor connection
11/25/2011 9:37:31 AMDave F
Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
11/25/2011 10:04:47 AMNorm Leal
Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
:Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
11/25/2011 10:27:33 AMDave F
:Dave
: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
:http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
Norm,
It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
11/25/2011 10:30:28 AMDaveF
::Dave
:: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
::http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
:::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
:Norm,
: It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
Make that #73 based on what I see on the schmatic.
11/25/2011 10:33:45 AMNorm Leal
To what pin is the cap attached? Since there isn't a .001 mf shown around your output tubes someone could added an extra cap?
::Dave
:Norm,
11/25/2011 10:59:10 AMDaveF
:Dave
: To what pin is the cap attached? Since there isn't a .001 mf shown around your output tubes someone could added an extra cap?
:::Dave
::: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
:::http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
::::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
::Norm,
:: It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
#73 is a .0015 which is the cap I believe is the issue. It looks like it would go from the same pin on each 41 one to the other and one may have become disconnected. I have run # 122. The schemnatic that you have here does show a cap running from output to output so I think this is the one. Do you agree that there should be a cap from output to output?
11/25/2011 12:10:10 PMNorm Leal
Hi Dave
Yes, there should be a cap between output of each tube. Pin #2 on a 41 or 42 tube. Schematic calls for .0015 but .001 mf could be used.
::Dave
:: To what pin is the cap attached? Since there isn't a .001 mf shown around your output tubes someone could added an extra cap?
::::Dave
:::: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
::::http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
::::Norm
:::::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
:::Norm,
::: It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
:#73 is a .0015 which is the cap I believe is the issue. It looks like it would go from the same pin on each 41 one to the other and one may have become disconnected. I have run # 122. The schemnatic that you have here does show a cap running from output to output so I think this is the one. Do you agree that there should be a cap from output to output?
11/25/2011 1:16:04 PMDaveF
:Hi Dave
: Yes, there should be a cap between output of each tube. Pin #2 on a 41 or 42 tube. Schematic calls for .0015 but .001 mf could be used.
:::Dave
::: To what pin is the cap attached? Since there isn't a .001 mf shown around your output tubes someone could added an extra cap?
:::::Dave
::::: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
:::::http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
:::::Norm
::::::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
::::Norm,
:::: It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
::#73 is a .0015 which is the cap I believe is the issue. It looks like it would go from the same pin on each 41 one to the other and one may have become disconnected. I have run # 122. The schemnatic that you have here does show a cap running from output to output so I think this is the one. Do you agree that there should be a cap from output to output?
Thanks Norm,
I reattached it but the radio and phono still make a motorboating sound when the volume gets turned up to the high end. I also note that the phono (which is no longer beam of light, it has a crystal rebuilt cart in it, has a raspy sound, too high pitched, and no base, I have seitched needles but no difference, any ideas?
11/25/2011 1:33:55 PMMarv Nuce
Dave,
I did the same thing to a 42-1008, swapped in a newer changer for the missing "Beam of Light" First removed the special xformer in the connection path, then built a special adapter (read loading) circuit per cartridge mfrs specifications, and bridged the stereo channels.
::Hi Dave
:: Yes, there should be a cap between output of each tube. Pin #2 on a 41 or 42 tube. Schematic calls for .0015 but .001 mf could be used.
::::Dave
:::: To what pin is the cap attached? Since there isn't a .001 mf shown around your output tubes someone could added an extra cap?
::::Norm
::::::Dave
:::::: Could it be a replacement for cap #84? If so it connects between pin #2 on each 41/42 tube.
::::::http://www.nostalgiaair.org/PagesByModel/439/M0013439.pdf
::::::Norm
:::::::Hello to all today. I have a 41-611 chassis that was recapped in the past and has a grounding issue while playing. I noticed a .001 mf @ 1000 volt cap that is attached to one of the #42 output tubes but the other end is unattached. Can anyone read the schematic and tell me where this other end connects? I can see it on the schematic but am unable to confirm where it goes. This answer would be greatly appreciated.
:::::Norm,
::::: It looks like #74 it is the original cap, they did not replace it, but it is attached to one of the 42's and the other end is unattached, I can see it on the schematic as the only .0015 @1000
:::#73 is a .0015 which is the cap I believe is the issue. It looks like it would go from the same pin on each 41 one to the other and one may have become disconnected. I have run # 122. The schemnatic that you have here does show a cap running from output to output so I think this is the one. Do you agree that there should be a cap from output to output?
:Thanks Norm,
:I reattached it but the radio and phono still make a motorboating sound when the volume gets turned up to the high end. I also note that the phono (which is no longer beam of light, it has a crystal rebuilt cart in it, has a raspy sound, too high pitched, and no base, I have seitched needles but no difference, any ideas?
