For those who have not seen these bias cells before, i hope that my pics are correct and provide information.
I have seen posts about putting them in boiling water to rejuvinate them, then seal them after they dry.
Mine reads 0.5 VDC with the radio operating, i am going to try to get it back to 1 VDC.
Other input is appreciated to help others.
Mitch
Nice photos.
In many cases you don't need the bias cell. Often these cells are biasing a 1st audio amplifier like #75 tube. Later radios didn't add bias on this stage. Just a straight connection and high value grid resistor, 4.7 or 10 meg.
Best to short across the bias cell but don't leave a bad one in the circuit. Open it will cause problems.
::Hello all,
::For those who have not seen these bias cells before, i hope that my pics are correct and provide information.
::I have seen posts about putting them in boiling water to rejuvinate them, then seal them after they dry.
::Mine reads 0.5 VDC with the radio operating, i am going to try to get it back to 1 VDC.
::Other input is appreciated to help others.
::Mitch
:Another picture.
Here is some additional info . . . as per their technical aspect . . . to be supplementing your submitted photos: 73's de Edd
:This little bias cell is a nostalgia piece of radio history. Someone thought it was a good idea. It’s cool to have the original keep going. There is some insignificant advantage to have it in circuit.
Tony
Is if this is what you have.
Mitch
Yes you can use a button battery, Bias Cells are rated at 1 to 1.5 VDC. Be careful on the polarity.
Or you can remove them and drop them into a cup of boiled water and wait for the small bubbles to stop, then dry them and measure the voltage, they should then last another 30 to 40 years.
Mitch
I just pat it down with a paper towel, let it air dry for an hour, then apply a thin bead of elmers glue to the edge and let it dry. What you do not want is the water leaking out.
Measure the voltage with a digital volt meter to assure polarity for at least 1 volt DC. Then re install the Bias Cells.
You will have kept the radio original in doing this and acheived some self satisfaction in your accomplishment and not with button batteries.
Mitch
