:That's what it has in it. ( No Tube Chart ) There is a big dog bone type dropping resistor in the heater line. The set does light up, and heater string is correct voltage. The problem is the single IF can has the oscillator coil on the same form. Two broken wires.
:Thought I typed 50L6. I see I didn't It's a TRF radio.
:This radio was found in as is condition. The 12F5 0ctal seems correct for the first RF tube from the antenna coil. The 12A5 apparently does not belong in the socket. The 50L6 is wired correct for the audio output. The 35Z5 is being the rectifier. Looks as if way in the past this set has been modified. Has brass rivets holding tube sockets. A strange TRF set.
:Sir Warren . . . . .
:So it IS Warren . . . .
:And that other tube numbering I.D. error on the 12A7 is that it was a 12A5 . . . . which is STILL giving us an A.F. output tube .
:How about looking at the volume control and its derived audio input source line from the preassumed detector area of the set.
:Possibly the missing tube is a pentode / diode which would be pretty hot in using a pentode in amplifying RF following that initial triode front end with the diode section providing for the detected audio.
:See if a 12SF7 might agree with the wiring present in that area . . . other wise find the pins that are close to ground . . . if utilizing a cathode resistor, as well as the tube pins having B+ on them, and if there seems to be a screen dropping resistor connected into that mystery tubes circuitry.
:That 12SF7 will sort of give you a marker with its pins 7 and 8 being used for filaments vice the commonly experienced pins 2 and 7 on octals.
:Appearances are not everything; it just looks like they are.
::This radio was found in as is condition. The 12F5 0ctal seems correct for the first RF tube from the antenna coil. The 12A5 apparently does not belong in the socket. The 50L6 is wired correct for the audio output. The 35Z5 is being the rectifier. Looks as if way in the past this set has been modified. Has brass rivets holding tube sockets. A strange TRF set.
