Crosley Model 601 Complete Operating Instructions
11/18/2011 11:59:39 PMRob W
Does anyone have the complete operating instructions for the above even a copy of what is often seen in the underside of the lid
11/23/2011 5:30:13 PMrob W
Has anyone had a search for this yet RW
:Does anyone have the complete operating instructions for the above even a copy of what is often seen in the underside of the lid
11/23/2011 6:58:57 PMDoug Criner
I have a Crosley 601 "Bandbox" that works. There is nothing pasted on the inside lid. What exactly is your problem - maybe we can help?
This is a TRF set with three RF stages, det, and two AF stages. It requires a high-impedance, permanent-magnet speaker - or a low impedance speaker with a speaker xfmr.
11/23/2011 11:42:10 PMEdd
Sir Ron . . . dub'l'ya. . . . .
Get your hat and coat . . . as well as your strongest maggot-flying glass out, as this might require a flying trip to "Chermany".
Seems like this submittor has one WITH that internal label intact within. . . . albeit a bit puckered, with one crease and yellowed somewhat.
But its not beyond using a photo of it to establish the spacing ,type set and ratios to replicate and then print and age with a wee spot o' tea soaking.
See if you can contact that person who owns it for that info.
Some people think my brother is weird, because he has sideburns behind his ears.
Me . . . I think he's weird, because he has false teeth . . . with braces on them.
:I have a Crosley 601 "Bandbox" that works. There is nothing pasted on the inside lid. What exactly is your problem - maybe we can help?
:This is a TRF set with three RF stages, det, and two AF stages. It requires a high-impedance, permanent-magnet speaker - or a low impedance speaker with a speaker xfmr.
11/23/2011 11:43:34 PMEdd
11/23/2011 11:44:42 PMEdd
:Sir Ron . . . dub'l'ya. . . . .
:Get your hat and coat . . . as well as your strongest maggot-flying glass out, as this might require a flying trip to "Chermany".
:Seems like this submittor has one WITH that internal label intact within. . . . albeit a bit puckered, with one crease and yellowed somewhat.
:But its not beyond using a photo of it to establish the spacing ,type set and ratios to replicate and then print and age with a wee spot o' tea soaking.
:See if you can contact that person who owns it for that info.
Third time was the charm . . . to get that link HOT !
:Some people think my brother is weird, because he has sideburns behind his ears.
:Me . . . I think he's weird, because he has false teeth . . . with braces on them.
::I have a Crosley 601 "Bandbox" that works. There is nothing pasted on the inside lid. What exactly is your problem - maybe we can help?
::This is a TRF set with three RF stages, det, and two AF stages. It requires a high-impedance, permanent-magnet speaker - or a low impedance speaker with a speaker xfmr.
