I own a Philco 38-10
It has a 6K7G in the IF stage.
Tube are not good.
I took temporary one good 6K7G from another good set i have. Then my Philco worked very well. Alignment has been done properly.
So i decided to make a replacement. I tried to replace the 6K7G by a metal 6K7 which has (i think) the same pin-out in my Philco model:38-10, but for some reasons, it doesn't work.
I tried to re-align the IF without success, i hear some sort of motorboating.
Question is: Why it is not possible to directly replace a 6K7G by a metal 6K7 ?
Are they so different ?
Is there anything i could modify to make my Philco 38-10 working with a 6K7 ?
Do you believe i could have better results with a 6SK7 (after re-wiring the socket of course) ?
Vianney
When using a metal tube make sure that pin one is connected to ground.
Mitch
Thanks for the tip.
Pin one was not grounded.
In fact there was no lug installed on pin 1 of the socket.
I have been force to replace the socket.
Radio play well now with a 6K6 and pin 1 to GND
Vianney
