http://www.bbcode.org/examples/?id=10
Thank You All So Much, George T
It says "Made in U.S.A. by D. R. CO. Detroit.
The model number is the one you found rubber stamped on the rear of the chassis, 116. This should be from 1936.
I have the identical cabinet, with a different chassis in it (probably a 104) that doesn't have the red and white dial.
:The answer is right on the bottom line of the patent plate. You have a Detrola.
:It says "Made in U.S.A. by D. R. CO. Detroit.
:The model number is the one you found rubber stamped on the rear of the chassis, 116. This should be from 1936.
