11/11/2011 2:43:30 PMrob w(98106:0)
Can you assist with the hookup of a n Arbee 111 battery eliminator to a Crosley Model 601
11/11/2011 3:40:21 PMEdd(98108:98106)
Sir Ron . . . . dub'l ya'. . . . .
I'll initially start off . . . but really need other referencing that is not with me at this locaton.
Red-------135 Volts B+ for your AF output stage
White-----90 Volts B+ for your frontal RF tubes and the first audios plate supply
Blue ------45 Volts B+ for your detector stages plate supply
Brown ---- The lower C minus supply for your first audio stages grid bias
Green------The higher C minus supply for your AF output tubes grid bias
Yellow------Filament supply
Black-------Filament supply and the B- supply's common connection.
What I need my other ref info is to confirm the polarities of the applied 5.1 Volt A supply to those Yellow and Black connections.
With this set using separate C supplies the black is probably common negative for both A and B supplies , whereas when slouching along WITHOUT using any C supplies . . .[used on much on simpler receivers] but (yours definitely not in that category ! ), one ties the A+ to B- ground and gets the benefit of that minor level of developed "phantom" C bias.
Thassit for now . . . .
I went to the eye doctor today and found out I needed glasses for reading. So, I got me some flip-up contact lenses.
:Can you assist with the hookup of a n Arbee 111 battery eliminator to a Crosley Model 601
11/16/2011 4:47:50 PMRob(98179:98108)
: : : : : : : : : : : : :Sir Ron . . . . dub'l ya'. . . . . : : : : :I'll initially start off . . . but really need other referencing that is not with me at this locaton. : : :Red-------135 Volts B+ for your AF output stage : : :White-----90 Volts B+ for your frontal RF tubes and the first audios plate supply : : :Blue ------45 Volts B+ for your detector stages plate supply : : :Brown ---- The lower C minus supply for your first audio stages grid bias : : :Green------The higher C minus supply for your AF output tubes grid bias : : :Yellow------Filament supply : : :Black-------Filament supply and the B- supply's common connection. : : :What I need my other ref info is to confirm the polarities of the applied 5.1 Volt A supply to those Yellow and Black connections. : : :With this set using separate C supplies the black is probably common negative for both A and B supplies , whereas when slouching along WITHOUT using any C supplies . . .[used on much on simpler receivers] but (yours definitely not in that category ! ), one ties the A+ to B- ground and gets the benefit of that minor level of developed "phantom" C bias. : : :Thassit for now . . . . : : : : :73's de Edd : : : : :I went to the eye doctor today and found out I needed glasses for reading. So, I got me some flip-up contact lenses. : : : : : : : |
::Can you assist with the hookup of a n Arbee 111 battery eliminator to a Crosley Model 601
