: I've been aligning an SP-210LX. Everything was OK until aligning the high (10-20 mhz) band. Using a signal generator and WWV (just to make sure), 10 mhz lines up with 10 on the dial, 20mhz lines up with 20 on the dial. 15 mhz however, comes in at 15.3 on the dial. I have replaced all the caps except for 3 molded mica ones (2 rf grid coupling and 1st det. signal grid coupling) as they tested fine, no leaks, shorts, etc. Any hints? Is this normal?
