:Hello All,
: I replaced all the paper and electrolytic capacitors in this radio. I checked all the tubes and double checked all my connections to make sure that I don't think I made any mistakes. All that works is the amplifier. The tuner is completely dead.
: The service data is so bad in Riders, it's difficult to find things in the circuit. Where is the voltage chart? I would like to make sure that all the tubes are on. I found two resistors that were way off value and replaced those. One was a 33K resistor that became a 300K ohm resistor and a 3K resistor that became an 8 K resistor. Everything I check is good, but it doesn't work.
: As usual, this is extremely frustrating. I have spent several hours accomplishing nothing. Where should I look for audio and where should I look for voltages on each tube in the tuner section?
: Either a voltage is missing or something is shorting out the tuner's output, is what it sounds like. But everything I check is good.
: Please help if you can.
:Thanks,
:Dave
