Storing Test Equipment in a Hot Shed
10/11/2011 6:27:13 AMLou
All:
I have recently acquired a bunch of test equipment> Unfortunately I do not have enough space in my house to hold it, so I am forced for the time being to store it in my shed.
I noticed that temperatures in the shed may climb reasonably high during a hot day - perhaps over 110 degrees F.
Should I worry about this? Wouldnt modern test equipment be able to survive these storage temperatures?
Thanks for any opinion
Lou
10/11/2011 8:33:32 AMEdM
:All:
:I have recently acquired a bunch of test equipment> Unfortunately I do not have enough space in my house to hold it, so I am forced for the time being to store it in my shed.
:I noticed that temperatures in the shed may climb reasonably high during a hot day - perhaps over 110 degrees F.
:Should I worry about this? Wouldnt modern test equipment be able to survive these storage temperatures?
:Thanks for any opinion
:Lou
Much of the equipment I come across had been stored in a shed / outbuilding. The problem is moisture condensation from changes in humidity and temperature. This has ruined many beautiful cabinets, and caused rust on chassis assemblies. Also be aware that vermin can be a problem, and depending on where you are, possible theft or mischief. I have been storing carefully boxed items in a hot attic in Texas, and over the space of 20 years, and have not noticed any problems. However, temperature and humidity changes are still a problem, and has rusted unprotected metal. To be on the safe side, on a hot dry day, I would put items in a plastic bag with a couple of moth balls, and / or put the items in a stryofoam cooler. Stryofoam coolers work great, because they mitigate temperature changes night to day. (Incidentally, moth balls will eat a little round hole in the bottom of some stryofoam coolers.)
