This is the Electrovox Model BX-326. BC-SW 10 Transistor SW radio. It's a large "Pocket" sized radio. It looks like it's from the 60s or 70s.
Do you think there is a chance that it is the same radio ?
I can provide you with the schematic of the Sharp if you like
:Sharp produced a model BX-326 (Circa 1964)with 10 transistors.
:Do you think there is a chance that it is the same radio ?
:I can provide you with the schematic of the Sharp if you like
:Here is an image of the Sharp BX-326 for you to compare:
:Service data sent
Now that you have the schematic do you have a signal tracer that you can use to find out where the signal appears or disappears ?
the center tap of the secondary of the driver transformer . . .or . . . |
BX-326 Transistor Radio Schematic Mark-Up: ![]() |
:Now that you have the schematic do you have a signal tracer that you can use to find out where the signal appears or disappears ?
:do you hear anything at all from the speaker.....hiss, static etc ? ...........or is it dead silent ?
:Sir Dave. . . . .
:Well . . . . in initially perusing over the units design, ( its shematic DOOOOOOWN bee-low) we see no hi value output stage to speaker coupling capacitor in the mix.
:With the unit, instead, using old style transformer to speaker drive.
:In the lineup of its multi decades old electrolytic capacitors used . . .ref to mark-up . . . CAPS A-B-C-D are power supply filtering / decoupling related and shouldn't knock out the set.
:Same is true of the E-F’s , which are related to filtering the AVC buss and also should not knock out the set.
:Electrolytic G up in the TR-7 collector circuitry is tone control function related, but could result in gain loss if being excessively leaky.
:Electrolytic I, is serving as a partial emitter bypass for TR-6 could account for slight gain drain, along with an accompanying bass decline, if decreased way down in capacitance.
:AND THEN . . . the major suspects would be AF interstage coupling capacitors H and J, if opened up.
:Other check points:
:Confirm if a “sprung open “ headphone jack switching mechanism is not opening up the path of the output transformer to the speaker, as well as ohmically testing the speaker voice coil.
:Kasper Pee Clodddd, special LOW tech . . . yet highly effective . . . “seat of pants” test procedure:
:Take a 1K resistor and clip lead connect one of its leads to this sets main BEE minus . . . . notice I did's say BEE Minus-es-es-es supply, since this set is incorporating a cluster of "upside down and backwards" Pee Enn Pee transisto-mo-fers. .
:The other lead is then taken and used in a manner like the “quick striking of a match” to any of the multi commonly connected junctions of:
: the center tap of the secondary of the driver transformer . . .or . . .
:Resistor R32. . .or . . .
:The Thermistor ( for temp comp) . . .or . . .
:Resistor R31 .
:Now if Tr-8 and Tr-9 are amplifying, that should result in a like burst of “scratch” noise emanating from the speaker.
:Move forward in the circuitry to Tr-7 transistor and perform the same “scratch test” on its BASE, but expect a much healthier aural response this time.
:Next test would be to “scratch” the BASE of the Tr-6 transistor stage and expect the loudest response yet.
:The final checks would be to run up the sets 5K volume control to its max volume position and “scratch “ both its rotor and high side terminal to verify that control, along with their responsive high level aural “scratches” coming from the speaker.
:That tests sequential completion should confirm the operationality of the audio chain on that unit, if BEE minus supply from the power supply and semiconductors---resistors---capacitors were all being O.K.
:If set is still inoperative . . .looks like RF is involved . . . will stand by at this time, awaiting your findings feedback.
:No time for a bath? . . . Simple . . . . just wrap yourself in masking tape and remove the dirt by simply peeling it off.
: BX-326 Transistor Radio Schematic Mark-Up:
::do you hear anything at all from the speaker.....hiss, static etc ? ...........or is it dead silent ?
::Now that you have the schematic do you have a signal tracer that you can use to find out where the signal appears or disappears ?
:Sir Dave. . . . .
:Resistor R31 .
:Sir Dave. . . . .
:Resistor R31 .
:Sir Dave. . . . .
:Resistor R31 .
:Edd,
: I guess I'm going to have to take the PC board out and check the other side. I can find nothing wrong, but it doesn't work. I find voltages to be ok. The transformers are not open. All the resistors are the correct value and connected where they are supposed to connect to. But no audio at the output or output stage. There's plenty of audio at the stage before though. As usual, this is getting frustrating. It should work, but it doesn't. Where do I look next?
:Thanks,
:Dave
::Sir Dave. . . . .
::Well . . . . in initially perusing over the units design, ( its shematic DOOOOOOWN bee-low) we see no hi value output stage to speaker coupling capacitor in the mix.
::With the unit, instead, using old style transformer to speaker drive.
::In the lineup of its multi decades old electrolytic capacitors used . . .ref to mark-up . . . CAPS A-B-C-D are power supply filtering / decoupling related and shouldn't knock out the set.
::Same is true of the E-F’s , which are related to filtering the AVC buss and also should not knock out the set.
::Electrolytic G up in the TR-7 collector circuitry is tone control function related, but could result in gain loss if being excessively leaky.
::Electrolytic I, is serving as a partial emitter bypass for TR-6 could account for slight gain drain, along with an accompanying bass decline, if decreased way down in capacitance.
::AND THEN . . . the major suspects would be AF interstage coupling capacitors H and J, if opened up.
::Other check points:
::Confirm if a “sprung open “ headphone jack switching mechanism is not opening up the path of the output transformer to the speaker, as well as ohmically testing the speaker voice coil.
::Kasper Pee Clodddd, special LOW tech . . . yet highly effective . . . “seat of pants” test procedure:
::Take a 1K resistor and clip lead connect one of its leads to this sets main BEE minus . . . . notice I did's say BEE Minus-es-es-es supply, since this set is incorporating a cluster of "upside down and backwards" Pee Enn Pee transisto-mo-fers. .
::The other lead is then taken and used in a manner like the “quick striking of a match” to any of the multi commonly connected junctions of:
:: the center tap of the secondary of the driver transformer . . .or . . .
::Resistor R32. . .or . . .
::The Thermistor ( for temp comp) . . .or . . .
::Resistor R31 .
::Now if Tr-8 and Tr-9 are amplifying, that should result in a like burst of “scratch” noise emanating from the speaker.
::Move forward in the circuitry to Tr-7 transistor and perform the same “scratch test” on its BASE, but expect a much healthier aural response this time.
::Next test would be to “scratch” the BASE of the Tr-6 transistor stage and expect the loudest response yet.
::The final checks would be to run up the sets 5K volume control to its max volume position and “scratch “ both its rotor and high side terminal to verify that control, along with their responsive high level aural “scratches” coming from the speaker.
::That tests sequential completion should confirm the operationality of the audio chain on that unit, if BEE minus supply from the power supply and semiconductors---resistors---capacitors were all being O.K.
::If set is still inoperative . . .looks like RF is involved . . . will stand by at this time, awaiting your findings feedback.
::73's de Edd
::No time for a bath? . . . Simple . . . . just wrap yourself in masking tape and remove the dirt by simply peeling it off.
:: BX-326 Transistor Radio Schematic Mark-Up:
:::do you hear anything at all from the speaker.....hiss, static etc ? ...........or is it dead silent ?
:::Now that you have the schematic do you have a signal tracer that you can use to find out where the signal appears or disappears ?
Thanks to all,
:Sir Dave. . . . .
:Resistor R31 .
:Did you check the earphone jack ? Sometimes those can be open due to someone jamming the wrong plug in it. Also the wrong power supply may have been used, or with the wrong polarity. Check the audio output transistors.
