:RCA Model 88K 1937, Rider 8-132 radio receives excellent, but when I turn power off kind of an echo or twanging sound from speaker for about 2 seconds as talking or music fades out. Any ideas as where to l@@k??
Text mesage left on mobile phone . . . |
:Hi; Checked all tubes & still after turning power off music or talking fades out. What else could be checked??
:Sir Bob. . . . .
:One would certainly want to logically suspect either that 6Q7 or 6F5 tube.
:Like its possibly some shrinking /compression /stretching of a tubes internal infrastructures elements on onset of thermal cool down.
:To see how far forward it is occuring, could you initiate an initial test of those two stages by starting at the 6Q7 and take a 10 ufd @50 V rating ( or upwards voltage) electrolytic cap and have its POSITIVE terminal to ground and its NEGATIVE goes to the 1st grid of the 6Q7.
:Now, that should DRASTICALLY change the tonal response of anything coming into that stage, almost to a "low burp" so DON'T expect any normal sound at all , but after the usual warmup time, turn off the set and see if the effect is now gone or just being a subtle "blurp".
:If the effect is unaffected and is as was, move that cap to the Firstus gridamus of the 6F6 AF outputsy tooberator and perform the same test.
:(My next suspicion would be the filters associated with the sets power supply . . . . . even new ones . . . if having adject ESR.)
:Standing by and waiting . . . . .with bated breath. . . . . I 'jes LUV's these WIERD 'lil mysteries.
:Text mesage left on mobile phone . . .
:370HSSV 0773H
:(You're looking at it upside down dummy !)
::Hi; Checked all tubes & still after turning power off music or talking fades out. What else could be checked??
Do make sure the Filter capacitors are of the correct value. Tube 6Q7 grid is top of tube, 6F6 grid is pin 5.
