George
There are approximately a dozen or so versions of the Graetz Comedia....all with different model numbers ......produced between 1954 - 1974.
Can you provide a specific model number ?
Dennis
Hi Dennis, Thanks for the reply
I do not see a model number per say. On the back cover it has Graetz Comedia Vollsuper. No numbers. On the chassis the is one set of numbers stamped: 737093
Would it help if I posted some pictures? If so, what views would tell you the most information?
George
:There are approximately a dozen or so versions of the Graetz Comedia....all with different model numbers ......produced between 1954 - 1974.
:Can you provide a specific model number ?
:Dennis
::George,
:Hi Dennis, Thanks for the reply
:I do not see a model number per say. On the back cover it has Graetz Comedia Vollsuper. No numbers. On the chassis the is one set of numbers stamped: 737093
:Would it help if I posted some pictures? If so, what views would tell you the most information?
:Thanks,
:George
::There are approximately a dozen or so versions of the Graetz Comedia....all with different model numbers ......produced between 1954 - 1974.
::Can you provide a specific model number ?
::Dennis
I believe I have identified the model from a picture on radiomuseum. It looks like the Model 4R416
:::George,
::Hi Dennis, Thanks for the reply
::I do not see a model number per say. On the back cover it has Graetz Comedia Vollsuper. No numbers. On the chassis the is one set of numbers stamped: 737093
::Would it help if I posted some pictures? If so, what views would tell you the most information?
::Thanks,
::George
:::There are approximately a dozen or so versions of the Graetz Comedia....all with different model numbers ......produced between 1954 - 1974.
:::Can you provide a specific model number ?
:::Dennis
