With your sets SSB mode working . . . it is concurrently using the SAME stages and processing that that would be involved for standard AM mode of reception. (***Ref )                   reception Initially . . . . Thassit . . . . |
:I have a National NC-303 from which I can pick up ssb but cannot pick up anything on AM mode. No movement on s-meter. Essentially have RF gain but no audio gain. Can someone point me to avc cirucit in this radio in terms of troublshooting components? I have tracked avc line from accesory socket back to V1 and it checks OK.
:Sir Brian . . . . .
:Misadjustment and /or / switch settings ?
:With your sets SSB mode working . . . it is concurrently using the SAME stages and processing that that would be involved for standard AM mode of reception. (***Ref )
:BUT, you does realizes-es that you has done founds yourself a receiver, that is geared exclusively for solely tuning the Am-a choor frequencies . . . don't you ?
:Whereupon, if you scan the Ham bands you might still find yourself one or two AM stations . . . .more likely on weekends or before mornings "go to work" time on a net fwequency . . . . (Elmer Fudd made me do it !)
:HOWEVER if you chance to tune into the 11 meter band you should still find quite a bit of operations by the Cee Bee'rs.
:(*** Ref )recontinuing on the related above
:Put the Mode switch at AM.
:Notch and Depth filter(s) OFF. . . . . (or you are potentially apt to suck up and swallow the whole IF signal.)
:Then locate the sets IF passband switching . . . . .and examine its mark ups.
:Do note the different IF passband settings with :
:S . . . . . . .(400 cps bandwidth) . . . . used for crowded CW code reception
:SB1 . . . . .(2 kc bandwidth) . . . . used for single side band reception
:SB2 . . . . (2 kc bandwidth) . . . . used for single side band reception
:M . . . . . . (3.5 kc bandwidth) . . . . used for AM reception
:B . . . . . . . (8 kc bandwidth) . . . . used for wider band AM reception and also TTY /FAX / WEA and transponder
: reception
:To get decent sounding AM, you will need to be in the last "M" or "B" bandwidth settings .
:Initially . . . . Thassit . . . .
::I have a National NC-303 from which I can pick up ssb but cannot pick up anything on AM mode. No movement on s-meter. Essentially have RF gain but no audio gain. Can someone point me to avc cirucit in this radio in terms of troublshooting components? I have tracked avc line from accesory socket back to V1 and it checks OK.
:I will try those settings. One thing I have noticed is that the cathodes on tubes 6BJ6 (V5 and V6) are running high, 11 and 6 volts respectively. I have changed most of the capacitors around those tubes, am I looking at a short somewhere that is drawing them up?
::Sir Brian . . . . .
::Misadjustment and /or / switch settings ?
::With your sets SSB mode working . . . it is concurrently using the SAME stages and processing that that would be involved for standard AM mode of reception. (***Ref )
::BUT, you does realizes-es that you has done founds yourself a receiver, that is geared exclusively for solely tuning the Am-a choor frequencies . . . don't you ?
::Whereupon, if you scan the Ham bands you might still find yourself one or two AM stations . . . .more likely on weekends or before mornings "go to work" time on a net fwequency . . . . (Elmer Fudd made me do it !)
::HOWEVER if you chance to tune into the 11 meter band you should still find quite a bit of operations by the Cee Bee'rs.
::(*** Ref )recontinuing on the related above
::Put the Mode switch at AM.
::Notch and Depth filter(s) OFF. . . . . (or you are potentially apt to suck up and swallow the whole IF signal.)
::Then locate the sets IF passband switching . . . . .and examine its mark ups.
::Do note the different IF passband settings with :
::S . . . . . . .(400 cps bandwidth) . . . . used for crowded CW code reception
::SB1 . . . . .(2 kc bandwidth) . . . . used for single side band reception
::SB2 . . . . (2 kc bandwidth) . . . . used for single side band reception
::M . . . . . . (3.5 kc bandwidth) . . . . used for AM reception
::B . . . . . . . (8 kc bandwidth) . . . . used for wider band AM reception and also TTY /FAX / WEA and transponder
:: reception
::To get decent sounding AM, you will need to be in the last "M" or "B" bandwidth settings .
::Initially . . . . Thassit . . . .
::73's de Edd
:::I have a National NC-303 from which I can pick up ssb but cannot pick up anything on AM mode. No movement on s-meter. Essentially have RF gain but no audio gain. Can someone point me to avc cirucit in this radio in terms of troublshooting components? I have tracked avc line from accesory socket back to V1 and it checks OK.
:I've found several small resistors that appear to be wire wound that are open around the wafer switches. They are small indeed, does the same colour coding apply to these? I like to double check the circuit with the colours. These are tiny resistors.
::I will try those settings. One thing I have noticed is that the cathodes on tubes 6BJ6 (V5 and V6) are running high, 11 and 6 volts respectively. I have changed most of the capacitors around those tubes, am I looking at a short somewhere that is drawing them up?
:::Sir Brian . . . . .
:::Misadjustment and /or / switch settings ?
:::With your sets SSB mode working . . . it is concurrently using the SAME stages and processing that that would be involved for standard AM mode of reception. (***Ref )
:::BUT, you does realizes-es that you has done founds yourself a receiver, that is geared exclusively for solely tuning the Am-a choor frequencies . . . don't you ?
:::Whereupon, if you scan the Ham bands you might still find yourself one or two AM stations . . . .more likely on weekends or before mornings "go to work" time on a net fwequency . . . . (Elmer Fudd made me do it !)
:::HOWEVER if you chance to tune into the 11 meter band you should still find quite a bit of operations by the Cee Bee'rs.
:::(*** Ref )recontinuing on the related above
:::Put the Mode switch at AM.
:::Notch and Depth filter(s) OFF. . . . . (or you are potentially apt to suck up and swallow the whole IF signal.)
:::Then locate the sets IF passband switching . . . . .and examine its mark ups.
:::Do note the different IF passband settings with :
:::S . . . . . . .(400 cps bandwidth) . . . . used for crowded CW code reception
:::SB1 . . . . .(2 kc bandwidth) . . . . used for single side band reception
:::SB2 . . . . (2 kc bandwidth) . . . . used for single side band reception
:::M . . . . . . (3.5 kc bandwidth) . . . . used for AM reception
:::B . . . . . . . (8 kc bandwidth) . . . . used for wider band AM reception and also TTY /FAX / WEA and transponder
::: reception
:::To get decent sounding AM, you will need to be in the last "M" or "B" bandwidth settings .
:::Initially . . . . Thassit . . . .
:::73's de Edd
::::I have a National NC-303 from which I can pick up ssb but cannot pick up anything on AM mode. No movement on s-meter. Essentially have RF gain but no audio gain. Can someone point me to avc cirucit in this radio in terms of troublshooting components? I have tracked avc line from accesory socket back to V1 and it checks OK.
