thanks
Just because sound stopped doesn't mean spreakers are bad. Schematics are listed above under Resources but you need a radio model number. If much newer than 1950 check here for schematics:
http://makearadio.com/beitmans/index.php
:I have the above stereo and sadly the speakers just died, as in stopped working with power. the radio and all that works fine but i need to know if there is a schematic or component i should look at or if it is a wiring issue. there is a bit of corrosion from mice from when it was in storage.
:thanks
