Resistors
8/26/2011 9:34:54 PMBob.
Is there a difference between regular more often used hard type resistors & the soft flexible cloth covered type resistors??
8/26/2011 10:00:23 PMMac
The "flexible" ones likely actual wire wound with a heat/flame resistant cover. The "hard" ones can be a resistive composition, wire wound covered with a coating or other. Wirewounds can have have inductance issues and can have a limited resistance range but can handle higher currents depending on the design. Where are you seeing the "flexible" ones?
8/27/2011 10:31:27 AMWarren
Sometimes the flexible resistors are used like a fuse in a high current draw application. It would be the weakest link in the chain to open first and not cause smoke and fire.
8/27/2011 11:32:59 AMBob
I'm recaping a 1939 Air King model 222,Rider 9-4,soft resistor going from 25L6 pin 8 to ground. I've notice this soft type resistor on radios from this time all the way into 50's tube type, so guess I'll replace with a hard type as this ones open.
8/27/2011 3:58:28 PMNorm Leal
Hi
I would use a 150 ohm @ 1 watt or greater for this cathode resistor. Even though it doesn't dissipate more than 1/2 watt still will be warm.
:I'm recaping a 1939 Air King model 222,Rider 9-4,soft resistor going from 25L6 pin 8 to ground. I've notice this soft type resistor on radios from this time all the way into 50's tube type, so guess I'll replace with a hard type as this ones open.
8/27/2011 4:25:06 PMBob
1 Watt, 150 ohm works great. Thanks
