This radio uses shielded wire in the audio section. Be sure someone hasn't replace it with regular wire. Very important to have shields grounded
http://www.nostalgiaair.org/PagesByModel/396/M0015396.pdf
:I have an RCA 45 record player/radio Model 9Y51 and it has hum on the radio. No hum with the volume turned down to zero. There is station sound but lots of hum in the background. Have tried tubes and recapped except for micas. Help!
Yes, I see several shielded wires in the audio and all seem to be fine and original. Also, getting hum whenever I touch the chassis.
::I have an RCA 45 record player/radio Model 9Y51 and it has hum on the radio. No hum with the volume turned down to zero. There is station sound but lots of hum in the background. Have tried tubes and recapped except for micas. Help!
::John
:: This radio uses shielded wire in the audio section. Be sure someone hasn't replace it with regular wire. Very important to have shields grounded
::http://www.nostalgiaair.org/PagesByModel/396/M0015396.pdf
:Yes, I see several shielded wires in the audio and all seem to be fine and original. Also, getting hum whenever I touch the chassis.
:::I have an RCA 45 record player/radio Model 9Y51 and it has hum on the radio. No hum with the volume turned down to zero. There is station sound but lots of hum in the background. Have tried tubes and recapped except for micas. Help!
