I took all of your comments in and I ordered the NTE 316 from Mouser Electronics to replace one bad transistor in a Zenith Transoceanic, a transistor part number 121-687.
The unit now works, however I did notice that the base and emitter leads on the replacement transistor exit the case at different locations that the original unit
(base and emitter leads are interchanged mechanically).
I was able to plug the transistor in properly with the change. I ASSUME that if I had not interchanged the base and emitter that the transistor would not work or even may be damaged, correct?
The replaced transistor is the RF amplifier front end unit in the FM tuner ( used to be a mixer in the AM section - I juggled the units around some ).
Just checking my work.
Thanks Again
Lou
All the Best,
Bill Grimm
That particular repair involved that sets FM aspect . . . . .and you were questioning the use of a 2N2222 or 2N2218 . . . . . well . . . in my case, I ended up using a 2N2222 in the FM RF slot. |
::Gentlemen:
::I took all of your comments in and I ordered the NTE 316 from Mouser Electronics to replace one bad transistor in a Zenith Transoceanic, a transistor part number 121-687.
::The unit now works, however I did notice that the base and emitter leads on the replacement transistor exit the case at different locations that the original unit
::(base and emitter leads are interchanged mechanically).
::I was able to plug the transistor in properly with the change. I ASSUME that if I had not interchanged the base and emitter that the transistor would not work or even may be damaged, correct?
::The replaced transistor is the RF amplifier front end unit in the FM tuner ( used to be a mixer in the AM section - I juggled the units around some ).
::Just checking my work.
::Thanks Again
::Lou
:Hi Lou,
: Odd those pins swapping, easy to believe, though.
: Had you plugged it in wrong, the transistor wouldn't be damaged. It wouldn't work, of course.
: It is a good thing you checked first rather than have to go into debug mode.
:All the Best,
:Bill Grimm
