Forum,
:Is there any extensive expertise out there on these new modern marvels. Cleaned the points on the old electro-mechanical part, and its running at 111cps with a bad pwr xformer, but how long will it last with a good xformer. Are these new SS parts as good as the old electro-mechanical parts. Its a Mopar 802 from a 49 Dodge, and appears to have negative ground according to radio schema.
:marv
:49 Dodge 6 volt system is a positive ground car. To use a solid state vibrator it would have to be one for positive ground. The use of a mechanical vibrator the polarity would not make any difference.
::If you look up any 49 Dodge, Plymouth, or Chrysler they were all 6 volt positive ground. I had a 53 Chrysler It too was 6 volt positive ground.
:In my teen years I had a friend who worked at a salvage yard; he gave me all the car radios I wanted. (Some I still have, but unfortunately I scrapped many of them for parts, or sold them.) Anyhow, for these old MoPar (and GM) radios, in stand-alone operation, it does not make any difference at all whether the positive or negative is 'grounded' to the radio chassis. In fact, the radio works fine if you short the vibrator, passing current to ONE SIDE ONLY of the vibrator transformer, and feed the radio with 6.3 VAC; you will need availability of 5 amps or more at 6.3 VAC. I put numerous of these and other grand old car radios in a sturdy wood box, with a speaker, and an old TV transformer, and sold them. They would rock the house! Some are still going to this day. EdM
