Before you go to the trouble of replacing the selenium unit, have you checked the level of the B+?
One way to see if the selenium is bad is to check the radio operation "cold" or at startup. Usually, as the selenium unit heats up it gets lossier, causing a drop in B+.
BUT I would not rush to change it. You should check all of the tubes with a reliable tester. You may also have some blocking effect with a bad cap as installed (yes - it happens).
Lou
:Hello All,
: I just replaced all 27 capacitors in this table radio. Unless a very very long antenna wire is attached to the radio it will receive nothing. When it does receive FM, the stations past the middle of the band come in ok, they sound very clear, but the radio cannot be blasted.
: I think I should hear FM hiss even if there's no antenna attached but I don't. It's pretty much silent between stations. I can also tune in all AM stations. It doesn't blast as loud as a 50L6 usually does. It should overload at full volume, but it doesn't. It also takes a little to long to warm up. So my guess is that the selenium rectifier is a little bit weak.
: I'll replace it and let everyone know if that made a difference. I haven't tested the tubes either. I'll do that too, even though they appear to be good, judging by how the radio sounds.
:Thanks,
:Dave
:Dave:
:Before you go to the trouble of replacing the selenium unit, have you checked the level of the B+?
:One way to see if the selenium is bad is to check the radio operation "cold" or at startup. Usually, as the selenium unit heats up it gets lossier, causing a drop in B+.
:BUT I would not rush to change it. You should check all of the tubes with a reliable tester. You may also have some blocking effect with a bad cap as installed (yes - it happens).
:Lou
::Hello All,
:: I just replaced all 27 capacitors in this table radio. Unless a very very long antenna wire is attached to the radio it will receive nothing. When it does receive FM, the stations past the middle of the band come in ok, they sound very clear, but the radio cannot be blasted.
:: I think I should hear FM hiss even if there's no antenna attached but I don't. It's pretty much silent between stations. I can also tune in all AM stations. It doesn't blast as loud as a 50L6 usually does. It should overload at full volume, but it doesn't. It also takes a little to long to warm up. So my guess is that the selenium rectifier is a little bit weak.
:: I'll replace it and let everyone know if that made a difference. I haven't tested the tubes either. I'll do that too, even though they appear to be good, judging by how the radio sounds.
::Thanks,
::Dave
