Thassit . . . .
:Hello All,
: Whoever owned this Simpson VOM before, put aluminum foil under the 1 Amp fuse and then ran the wire directly from that fuse to the selector switch.
: Does anyone has some pictures of where the original internal fuse connected. I have the schematic and service data but that doesn't have pictures.
: Also the negative D-Cell battery terminal was completely corroded. I think a strip of sheet metal should work to replace it, or is the original part still available somewhere?
: The condition of the meter is very good other than that. It works too. But I want to put the fuses in there like they were originally.
:Thanks,
:Dave
Sir Dave . . Dave . . Dave. . . . .
Even in using the better SCHEMA copy placed in the manuals copy . . . it further helps to click on and highlight it in blue to afford somewhat better contrast of the schemas line tracings.
73's de Edd |
Thanks, Dave
Hello All,
:Sir Dave . . Dave . . Dave. . . . .
:That dude 'soitanly looks oooold . . . . but the fusing just looks to be a SERIES arrangement of TWO fuses in the common negative input jack of the meter front panel.
:Examine the plethora of photos provided here on positioning of the LARGE HV BUSSMAN 2 A fuse like we see being used in Fluke digitals and then the small fast acting 1 amp that is being separate and is physically located near the batteries.
:Photos of the unit:
:The operators manual . . . for its BETTER schema:
:This is the manual for the unit and DO use its schematic, since the other stand alone one offered, looks like they made it on a toner starved copier !
:Even in using the better SCHEMA copy placed in the manuals copy . . . it further helps to click on and highlight it in blue to afford somewhat better contrast of the schemas line tracings.
:Thassit . . . .
::Hello All,
:: Whoever owned this Simpson VOM before, put aluminum foil under the 1 Amp fuse and then ran the wire directly from that fuse to the selector switch.
:: Does anyone has some pictures of where the original internal fuse connected. I have the schematic and service data but that doesn't have pictures.
:: Also the negative D-Cell battery terminal was completely corroded. I think a strip of sheet metal should work to replace it, or is the original part still available somewhere?
:: The condition of the meter is very good other than that. It works too. But I want to put the fuses in there like they were originally.
::Thanks,
::Dave
:Thassit . . . .
::Hello All,
::Thanks,
::Dave
http://www.simpson260.com/260-6/simpson_260-6m_inside_right.jpg
: Hi Dave ,
: Maybe this link will give you a better view of the right side of the Simpson 260-6M meter and the larger 2 Amp fuse, when you remove the case ! Lee
: http://www.simpson260.com/260-6/simpson_260-6m_inside_right.jpg
:Lee,
: Yes, I see the fuse in the picture. But it's missing from my 6M. Where do I get a new holder and fuse and what does it screw into. There seems to be no screw hole anywhere in my 6M. Was there a 6M made that didn't have the big fuse and just had the small one?
:Thanks,
:Dave
:: Hi Dave ,
:: Maybe this link will give you a better view of the right side of the Simpson 260-6M meter and the larger 2 Amp fuse, when you remove the case ! Lee
:: http://www.simpson260.com/260-6/simpson_260-6m_inside_right.jpg
: Hi Dave,
: Here is a link to a large group of the Simpson meters, that maybe helpful !
: The 6 and the 6M "are identical instruments electrically and mechanically, except that the 6M is equipted with a mirrored dial to eliminate parallax" as stated in my Series 6 and 6M operators manual , both show only one, 1 amp fuse ! If you would like I could email the schmetics from my operators manual, if you could give me your email address, mine is lee_mar_petrie@yahoo.com ! Lee
::Lee,
:: Yes, I see the fuse in the picture. But it's missing from my 6M. Where do I get a new holder and fuse and what does it screw into. There seems to be no screw hole anywhere in my 6M. Was there a 6M made that didn't have the big fuse and just had the small one?
::Thanks,
::Dave
::: Hi Dave ,
::: Maybe this link will give you a better view of the right side of the Simpson 260-6M meter and the larger 2 Amp fuse, when you remove the case ! Lee
::: http://www.simpson260.com/260-6/simpson_260-6m_inside_right.jpg
