7/29/2011 11:41:30 AMDave in CT(96600:0)
My Zenith 6s152 started shorting when I turn it on, but If I remove the rectifier the short and burning and smell stop.Is it possible the power transformer is not shorted/bad? I had heard a way to test the transformer is to remove the rectifier, is that true?
7/29/2011 12:36:00 PMWarren(96601:96600)
Without the rectifier tube in place, the secondary side of the transformer has no load on it. the transformer itself is most likely okay. There's a short in the B+ supply that is the cause of the problem. Or could even be the rectifier tube is shorted.
7/29/2011 12:47:18 PMDave in CT(96602:96601)
:Without the rectifier tube in place, the secondary side of the transformer has no load on it. the transformer itself is most likely okay. There's a short in the B+ supply that is the cause of the problem. Or could even be the rectifier tube is shorted.
The short started when I attempted to connect a oscillating phono to an imput jack and then to the antenna leads, at different times to test the phono, which was just rebuilt.. I don't know how that could have caused a short, but it did, and even though nothing is connected any longer, it has a definite short.
7/29/2011 1:05:15 PMcodefox(96603:96602)
You most likely have a bad (shorted) filter capacitor.
If this set has not been recapped, now's the time. The burned resistor(s) will have to be replaced too.
::Without the rectifier tube in place, the secondary side of the transformer has no load on it. the transformer itself is most likely okay. There's a short in the B+ supply that is the cause of the problem. Or could even be the rectifier tube is shorted.
:The short started when I attempted to connect a oscillating phono to an imput jack and then to the antenna leads, at different times to test the phono, which was just rebuilt.. I don't know how that could have caused a short, but it did, and even though nothing is connected any longer, it has a definite short.
7/29/2011 1:29:57 PMDaveF(96604:96603)
:You most likely have a bad (shorted) filter capacitor.
:If this set has not been recapped, now's the time. The burned resistor(s) will have to be replaced too.
:::Without the rectifier tube in place, the secondary side of the transformer has no load on it. the transformer itself is most likely okay. There's a short in the B+ supply that is the cause of the problem. Or could even be the rectifier tube is shorted.
::The short started when I attempted to connect a oscillating phono to an imput jack and then to the antenna leads, at different times to test the phono, which was just rebuilt.. I don't know how that could have caused a short, but it did, and even though nothing is connected any longer, it has a definite short.
I had replaced them all about 5 years ago, perhaps what I did on the input side, shorted one of the 3 of them, will replace and give it a try, thanks for the advice.
