other side
Thank you for the help!
Its side one . . . well done . . . .side two . . . medium well done. |
Ye olde . . . . Halliscratchers SX-88. . . . . ![]() |
:::Hi group-Frank here with the '54 sx-88..can anyone here eyeball-ID the value of this fried resistor?
::other side
:here's a shot while still in the rig
:Thank you for the help!
: : : : ![]() : : : : : : : :Sir Frank . . . . . : : :Well I tell you whuts . . . in lookking at the sizing perspective, relevant to the graining straitions in the oak wood displayed upon, that is looking to be a 1/2 watt resistor, with enough colorization left o be confirming the last tolerance banding as being a 10% tolerance unit. : :Its side one . . . well done . . . .side two . . . medium well done. : : :Now I was fully expecting that to be a Bee Pluckinbothus + feed off resistor branching off from the power supply and in seeing the RED first band, I was going for a 22-- 220-- 2200-- ohm unit and the thre4shold is up at the 20K to be able to char like that with the sets available level of B+. : : :Looks like 2.2 K is definitely the word. : : :Thank "goooness" for your last photo-ma-graph-a-mus, as one can readily see the "hyperventilating" Bumble Bee .047 bypassing capacitor at fault . . . . with its express ticket . . straight out of split city ! : : :I can make out the IF transformers 390 pf mica capacitor in the photo . . . but there are LIKE replications on the other two IF stages . . . so check out my RED-ORANGE- FUCHSIA mark ups to see WHICH was the one that failed on you. : : :Needless to say . . . you have some replicative cap replacement in other areas for PM aspects for the future. : : :I had almost completely forgotten about that particular series of receiver . . . that do be one one NICE . . .but massive unit ! : : :Thassitt. . . . : : :Schema Thumbnail referencing at vewy-vewy bottom . . . . : : : : : : : :73's de Edd : : : ![]() : |
: : : : Ye olde . . . . Halliscratchers SX-88. . . . . : : : ![]() : : : : : |
