It sounds as if your filter caps have finally failed. If you are looking for the higher working voltage caps that are used in these, check Antique Electronic Supply, Digikey (the source I use for rebuilding the old caps for maintaining appearances), and a whole host of others too.
: I recieved a Zenith B600 Trans-oceanic radio from my grandfather. About 9 years ago it still worked. I just got back into old radios and dug it out, it turned on but the speaker only makes a loud humming sound. I don't know how to fix this. If you have any info or schematics for this radio please email me. It would mean alot to get it working again. Thank You
: Thanks
Try http://www.transoceanic.nostalgiaair.org/
The information you want is posted there
