A padder cap will be in series with the oscillator circuit in a radio when each section of a tuner is the same size. Usually adjustable by a screw and mounted under the chassis.
Here is the reason for a padder. The oscillator in a radio operates IF frequency above received station. It takes less of a capacity change to cover a range of frequencies above the received signal.
Since each tuner section will have the same capacity change a padder is added in series to reduce tuning range of the oscillator. Later radios used tuners with different size sections.
::Hi everyone,
::It may sound silly but I shall ask anyway. What is a "padder" capacitor? I read about "rock the padder into correct alignment" and "padder capacitors for low end tuning ranges". I looked into The Little Oxford Dictionary and there do not seem to be such a word. Basically, what are padder capacitors and where can I find them on a schematic?
Count how many turns forward (by 1/4 turns is good enough) to where it becomes tight and write the number down or you will forget it. Then unscrew all the way, very carefully remove the mica, it is extremely brittle, spray everything with deoxit, mica should be clear when you are finished. If not, you can use paint thinner as a solvent. Let everything dry for a few hours, reassemble, make tight and loosen the same amount as you tightened. You will then be approximately in the same place you were before, but a touch up of the alignment will still be in order.
::Hi
:: A padder cap will be in series with the oscillator circuit in a radio when each section of a tuner is the same size. Usually adjustable by a screw and mounted under the chassis.
:: Here is the reason for a padder. The oscillator in a radio operates IF frequency above received station. It takes less of a capacity change to cover a range of frequencies above the received signal.
:: Since each tuner section will have the same capacity change a padder is added in series to reduce tuning range of the oscillator. Later radios used tuners with different size sections.
::::Hi everyone,
::::It may sound silly but I shall ask anyway. What is a "padder" capacitor? I read about "rock the padder into correct alignment" and "padder capacitors for low end tuning ranges". I looked into The Little Oxford Dictionary and there do not seem to be such a word. Basically, what are padder capacitors and where can I find them on a schematic?
:Thank you Norm. I had thought that it was the station tuning capacitor.
:Yen
