You have a model RP-176 changer in that set. Here is the service info: http://www.nostalgiaair.org/Resources/794/M0015794.htm
RF
::: i have a rca 612v3 - how do you remove the turn table it seems to be slipping would like to check out wheel or belt drive
:: There may be a snap ring holding the platter to the spindle. The drive would be underneath the platter.
:no snap ring even took a look from the inside underneath im wondering if thier screws underneath the rubber pad the records sit on
