7/15/2011 6:38:07 PMGeorge(96383:0)
Hi all I could use some help.. On the RCA up972 schematic I understand the + and - leads (all go to chassis ground) of the three 2mf caps but the 2 larger blocks of 4/7mf caps I am not sure what is + and negative.. The two large blocks are hooked together...Is this - and other 3 terminals are +
7/16/2011 6:31:30 PMEdd(96393:96383)
Sir George. . . . . (now . . . .really ? )
In inspecting the circuit paths of the power supply and the polarities involved
The black and red diamonds are indicative of the experienced polarities
I consider that mark up (that I placed in the yellow area) as a glitch that the schematic drafter introduced, considering the commonality of the terminal designations being at the bottom on the other like cap unit.
:Hi all I could use some help.. On the RCA up972 schematic I understand the + and - leads (all go to chassis ground) of the three 2mf caps but the 2 larger blocks of 4/7mf caps I am not sure what is + and negative.. The two large blocks are hooked together...Is this - and other 3 terminals are +
7/16/2011 7:59:31 PMGeorge...Ahhhhh HA...(96396:96393)
Thats what I thought..something just did not look right:
